The SOHC/4 World Tour is in under way.
Are you sure the bike is a K6?? The chain length and rear sprocket teeth sound like K7/K8, with 630 chain. These had 15 teeth on the front sprocket. You can verify the chain size by measuring the center-to-center distance on the chain rivets. 530=5/8", 630=3/4".
The K7 630 chain has 88 links, but also has a longer swing-arm. You might have a K7/8 motor in a K6 frame?Does anyone know off the top of their head if any of the F models used 630 chain?
Ok, so it is definitely a K6. I know I've checked before but I made sure by taking the numbers as follows:Engine - CB750E-2437857Frame - CB750-2548729The VIN badge also says manufactured 9/75 so I assume a K6.Chain is indeed a 630. Spacing on rivets is 3/4" on center. The wheel as I've mentioned before is a 120/90-18 so is it possible the PO cannibalized a hub from a K7/8 and laced it to my 18" wheel? Or perhaps just switched sprockets? I thought it strange when I found out that one of the spare wheels he gave me turned out to be a 17" with the sprocket side of the hub missing and exposing rubber boots inside the hub(don't know what they're called :/ )
Anyone else want to weigh in here?
So far it looks like you just need to get the proper 530 stuff. Still curious about how the PO fit a 630 front sprocket on a K6 counter-shaft; they mount differently.
Wow, Hino, that is really cool! Not that i would use or want it. Just that it was there. Probably solves the mystery, too.
The front sprocket is easy to replace. There should be a retainer plate fastened to the sprocket with two bolts. Remove the bolts, rotate the plate until it lines up with the splines on the counter-shaft, and it pull it off. Then the sprocket slides off. (does the K6 still have the auto chain oiler?)
