Author Topic: Hypothetical Question  (Read 2249 times)
Offline wedoo2
« on: November 15, 2011, 02:59:26 PM »
Let's say, hypothetically of course, that someone is thought to have hooked up their battery, positive to negative, backwards?  Myth has it that there was a mystical smoke about the area of all the side panel wires.  It goes without saying that this is the kind of person that should not be lead to an area where tools would lie.  Hah!  I shudder to think of this person working on one of my vehicles.
But, let us say that this scenario took place.  And even though our intrepid craftsman was quick as lightning (an apt adjective)and removed the errant wiring; and miraculously his lights came on when the key was turned.  Would our feeble minded one have cause to worry what he had done to his electrical system?
Hypothetically, of course.
Some days the sun is too loud.
Offline Gordon
  • 750K1, 550K2
Re: Hypothetical Question
« Reply #1 on: November 15, 2011, 03:15:10 PM »
This person would have hypothetically killed his/her rectifier, and hypothetically melted the green wire from the rectifier up to an unknown point in the harness, along with any adjacent wires, and will hypothetically need to replace said rectifier and any involved wires along the way.
Don't feel too bad, the writer of this response may have, hypothetically, been one of the many sohc4 owners who have, hypothetically, done the exact same thing in the past. :)
Offline GammaFlat
« Reply #2 on: November 15, 2011, 03:23:55 PM »
The rectifier's fate is quite certain but other damage is not.  Good luck.
K6
K7
Suzuki GN400 - Ignition fixed!
03 KLR650 - Doesn't do anything very well but.. well.. does everything.
Offline weekend_junkie
  • I bet you think I'm some
  • Member # 15859
« Reply #3 on: November 15, 2011, 03:38:11 PM »
I have a smart-charger that senses the polarity so this never happens, hypothetically or in reality.
I'm also certain it was about $30 and is black & yellow, but I forget the brand.
Dan
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #4 on: November 15, 2011, 03:42:41 PM »
Had a friend, that knew a guy, that his fiance's brother was roommates with, that installed a battery backwards once.   It wouldn't charge, but everything else worked fine.  Story has it, he eventually found his error and only had to replace my, I mean his, rectifier.
Offline wedoo2
« Reply #5 on: November 15, 2011, 03:57:08 PM »
Of course there is always one know-it-all in the crowd that has an answer for everything. :'(  But, grudgingly, he must be thanked.
Seems that this particular part, a rectifier, is the most expensive on the motorcycle.  Foolishness is always rewarded.  I'll pass on this advice if I ever hear of this happening.
Offline Tews19
  • I am no
« Reply #6 on: November 15, 2011, 03:59:27 PM »
If you removed it fast enough you may not have that bad of fate.
1970 Honda CB750 survivor.
Offline CycleRanger
  • No comment about being an
« Reply #7 on: November 15, 2011, 03:59:52 PM »
Expensive?  Not at all.
http://forums.sohc4.net/index.php?topic=12465.0
I replaced mine for about $15. :)
Offline wedoo2
« Reply #8 on: November 15, 2011, 05:46:23 PM »
Thank you.  Can the rectifier be tested?
« Reply #9 on: November 15, 2011, 05:54:23 PM »
Did you hook a battery charger up to it in reverse, (per weekend_junkie) or
Did you hook the bike to the battery in reverse? I didn't think this could be done, the wires wouldn't reach.
Hmmm.
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #10 on: November 15, 2011, 05:57:42 PM »
It can, run the bike and see if the battery Hypothetically dies. If it lives with over Hy pothectically 12+ volts. If it doesn't, spend the 15 dollars and Hy pothectically thanks for the lesson.... :-X
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
« Reply #11 on: November 15, 2011, 06:25:56 PM »
Hypothetically a good question!
Offline wedoo2
« Reply #12 on: November 15, 2011, 07:05:22 PM »
Well, it seems that there may be some masked sarcasm in these replies.  Surely you wouldn't think I would do such a thing?
« Reply #13 on: November 15, 2011, 07:13:45 PM »
Hypothetically, no!
Offline Gordon
  • 750K1, 550K2
« Reply #14 on: November 15, 2011, 08:11:05 PM »
He saw smoke, which means it was connected long enough to burn insulation on the wires, therefore it's toast.
« Reply #15 on: November 15, 2011, 08:16:26 PM »
the smoke should be left to circulate throughout the loom not escape it,if the battery is connected in reverse it will push the smoke backwards and cause it to backup untill it bursts a wire and comes out smelly,hypothecticaly
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #16 on: November 16, 2011, 08:31:22 AM »
He HYPOTHEICALLY saw smoke, which means it was HYPOTHEICALLY connected long enough to HYPOTHEICALLY burn insulation on the wires, therefore it's HYPOTHEICALLY toast.
Fixed that for ya.  ;)
« Last Edit: November 16, 2011, 09:45:33 AM by DukieFrankenkit »
Offline Rgconner
« Reply #17 on: November 16, 2011, 09:25:11 AM »
Did you cross the streams?
Never cross the streams, that would be bad.
1975 CB550K aka "Grease Monkey"
72500john
« Reply #18 on: November 16, 2011, 04:31:38 PM »
thats one sure way to prove how electricity works..if you let the smoke out it doesnt work anymore. cant say i ever did that myself..opps yea i did!
this kinda relate to a sayiing an old guy once told me related to shooting blackpowder guns. there are two kinds of blackpowder shooters out there. those that have loaded thier guns without powder..and those that eventualy will!!
