Author Topic: Rebuild the K6 engine("chong" in gearbox) or the parts engine(K3)?  (Read 930 times)
Offline Pecantree
Soon my brother will be hauling my 750 k6 back to Austin for me. Had to abort my trip and bike in Charlotte. I first posted about this here.  http://forums.sohc4.net/index.php?topic=96488.msg1075703#msg1075703
The engine has 38000 on it and seems to run fine other than the noisy cam chain when cold. The gearbox makes a repetitive "chong" sound in gear. Whatever is hitting has enough time to reverberate before it hits again.
I bought a k3 engine of unknown mileage and condition.
What's the better engine (all else being equal)? Should I do the K3 or hold off and redo the K6? I don't plan on making any structural changes. Been reading Hondmans book, the manual, and these forums. Usedta rebuild VW engines so I know I can do this.
Thoughts?
Offline Rigid
  • She likes a
    • KingCustomCycles
Re: Rebuild the K6 engine("chong" in gearbox) or the parts engine(K3)?
« Reply #1 on: November 18, 2011, 08:55:18 AM »
I would be curious what was wrong in the K6 and tear it down for a look.  You could get the K3 running and see if it is a keeper.  Seems to be the shortest route from A to B if the K3 is solid.  If not, make one good engine out of the two with a set of rings and a gasket set.  Once you are into the two teardowns, if it comes to that, it will go quickly.
