Author Topic: Carb Insulator Leaking Question (1981 CB650C)  (Read 2403 times)
Offline F16Viper68
« on: November 19, 2011, 09:31:40 AM »
I have a 1981 CB650C I've been slowing resurrecting and I have a question.  I noticed the #1 cylinder doesn't always fire (carb's rebuilt, new plugs, has spark, compression good) so I started checking for an intake leak and sure enough the #1 insulator is leaking (RPM increase with starting fluid).
The question I have is will this prohibit the cylinder from firing?
Also I'm finding the carb insulators online for $16.26 and the bands for $8.32.  Does anyone know of where I can get them cheaper?  Or is this as good as it gets?
Thanks in advance.
Dave...
Offline Steve_K
Re: Carb Insulator Leaking Question (1981 CB650C)
« Reply #1 on: November 19, 2011, 12:55:55 PM »
For a bodge, try wider hose clamps.  May tighten the insulator enough to run better til you replace them.
Cheap fix, one clamp and you know if thats the problem.
Steve
Steve_K
Offline Doggie
  • CB550F, CB650c, CB550k, Cb750K
« Reply #2 on: November 19, 2011, 08:36:26 PM »
I have a 1981 CB650c also and I have my insulators soaking in power steering sealer fluid to soften them up
while i'm rebuilding the carbs. Might make them soft enough to make a good seal. Good luck.
                                                           Doug
Offline F16Viper68
« Reply #3 on: November 20, 2011, 06:48:18 AM »
Steve
Not a bad idea. I noticed they are cranked all the way down.
Offline F16Viper68
« Reply #4 on: November 20, 2011, 06:50:34 AM »
                                                           Doug
I'm really not sure anything's going to work since I notice cracks on the engine side of the insulators when I was rebuilding the carbs.  Just another part of the puzzle that is this bike.
Off to Ace Hardware to buy some stuff to help me replace the fork seals on this thing.  Seems the 81 CB650C fork seals are different than most.  First time I've seen the manual say "take to dealer".   :o
Offline fmctm1sw
« Reply #5 on: November 20, 2011, 06:53:43 AM »
That price may be as good as it gets.  I bought mine from motogrid at about that price.
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Mainerider
  • '04 VFR 800, '96 VFR750, 2001 SV650
« Reply #6 on: November 21, 2011, 06:50:22 PM »
No need for you to take it to the dealer for the front fork service. I have an '80 and a friend has an '81. The only difference (and I've replaced the fork seals and bushings in both of the bikes) is the air hose fittings for the air-assist front suspension on the '81.  It slows you down a few minutes because you have to remove the crossover air line but that's about it; both models are the same, bushing-inteference fit design.
 Read the manual carefully on the air line removal; not difficult but it's easy to get confused over which part of the fittings to turn in which direction.  Really, it's no more difficult than changing the seals on the  79 and 80 forks; especially if you have the proper bushing/seal driver to use. Let me know if you need any more help; I've replaced several sets on various CBs and other models.
« Last Edit: November 22, 2011, 04:23:55 AM by Mainerider »
Offline F16Viper68
« Reply #7 on: November 22, 2011, 04:19:39 PM »
Yeah it wasn't too hard once I figured out the process.  I guess they figure nobody has a press/clamp?
http://forums.sohc4.net/index.php?topic=98191.msg1100717#msg1100717
Dave...
Offline cb650
« Reply #8 on: November 23, 2011, 12:37:10 AM »
Can u post where and the part # for the insulators.  I need a couple.
Offline F16Viper68
« Reply #9 on: November 23, 2011, 06:47:53 AM »
http://www.cheapcycleparts.com/model_years/88-honda-1981-650-custom-cb650c/assemblies/1424
Insulators: p/n 16211-460-770 $16.26
Bands: p/n 16219-422-000 $8.32
Dave...
Offline cb650
« Reply #10 on: November 23, 2011, 11:35:16 AM »
Cool thanks.  Latest bike needs a couple replaced.
