Author Topic: OEM screws for lamp lenses  (Read 1187 times)
Offline phil71
« on: November 19, 2011, 05:33:59 PM »
Ok, so this nuts, but while you can still get all the lenses for a K1, you can't get the dammed screws. I need some for the tail light, and some for the signals. Anyone have an idea that doesn't involve using threaded rod? THanks!
Re: OEM screws for lamp lenses
« Reply #1 on: November 19, 2011, 06:51:08 PM »
a decent bolt supply place should have them,i replaced mine with stainless.
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #2 on: November 19, 2011, 09:37:22 PM »
I have 4 t/light lense screws coming with a new gasket coming from David Silver to match the lense I got from you Dave.  ;)
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
« Reply #3 on: November 20, 2011, 01:52:59 AM »
gday frosty,,i mostly just use stainless anywhere and everywhere,they are cheap if you buy a few,when i walk into the local bolt shop here now they ask what do you want in stainless?you still havent fitted that lense yet?
Offline Raul CB750K1
« Reply #4 on: November 20, 2011, 02:11:02 AM »
A while ago -couple years- I bought new turn signal lens gasket and screws from Honda...
Offline Frostyboy
  • Circa 1951
« Reply #5 on: November 20, 2011, 02:35:53 AM »
Yeah, the lense has been on since then, but with only 3 daggy screws & the gaske is all twisted up. I'll have to tidy the old girl up a bit with the Mac coming from CoachDoc.  ;)
We haven't met yet.
[CB550F1]
Offline Irukandji
« Reply #6 on: November 20, 2011, 09:15:32 AM »
I have no problem finding lens screws but cant find out what size the turn signal ground screw on my 73 750 is.
I don't remember seeing them listed in parts fisch. Any help with that?
750k3
Offline buffaloejon
« Reply #7 on: November 20, 2011, 09:53:44 AM »
Mine (the lens screws) were M3x25's. I got them from fastenal for a dirt cheap price, like 2 bucks for 12 of them or something. When I picked up the order, they had given me 100 of them, because someone was too lazy to count out 12 and break up the lot, so I got 88 of them free.
If you want some, I'll send 'em to ya in a normal envelope in a baggie so it'll only cost a stamp for me, and nothing for you!
edit: These screws were for a 76 750K with stock lenses, so I'm not sure what else it would work with, but I'll send em if you want 'em.
« Last Edit: November 20, 2011, 09:56:10 AM by buffaloejon »
Engineers like to solve problems. If there are no problems handily available, they will create their own problems.
76 CB750K
http://photobucket.com/buffaloejon
Offline phil71
« Reply #8 on: November 20, 2011, 11:27:37 AM »
Hi Buffalo, that is amazing of you. I will have a look to see if they are the same part #. I also found a bolt/nut supply in the area that MIGHT have them. I thought they were so proprietary that it wouldn't be 'off-the-shelf', but Dave has inspired me to try.
Offline buffaloejon
« Reply #9 on: November 20, 2011, 12:20:14 PM »
Yea, its no big deal for me, I'm never going to use all of them, and postage is what, 50 cents?
I had a tough time finding them cause M3 is not a very common size. All the big-box stores only carry down to M4 around here.
76 CB750K
