my picture wont load,,you must index your tdc mark,,itll be wrong otherwise,,someones ten degrees might be eight or seven?its no big deal once your moving and revving,,advance your timing till it just pings/detonates,and then back it off till it stops just,even if the ignition was of a little,,back in the day all these hondas had to do was eat british iron,and they did even in not quite true tune off the floor,,the biggest issue with the points in these is syncing the 1/4 2/3 pair,any electronic system will jump this hurdle,this is where the home learner has trouble,it can be close and good enough,and that will do in most cases,and the bike will run perfect per say,,not good enough for many though,electronic will sync the pair which is half the battle.
EDIT.. picture loaded.
