Author Topic: Jetting the CB550 PD series carbs....  (Read 20260 times)
Offline lucky
Re: Jetting the CB550 PD series carbs....
« Reply #50 on: May 01, 2012, 04:17:09 PM »
I would say drive it around for a couple days, and then check the outside plugs again.
Let us know.
I think it is too early to make any more decisions.
Offline Scott S
« Reply #51 on: May 01, 2012, 07:14:40 PM »
 Will do. I think I figured out some air box assembly mistakes I made, too. I'll get that right, clean/oil the filter and get the snorkle back on and see what that does.
 She runs really nice with good engine temps, but the exhaust temps may be a touch high....a little over 400 degrees. Nowhere on the head or cylinders is anywhere close to 300 degrees, mostly in the low-mid 200's.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline cocinero196
« Reply #52 on: November 15, 2015, 05:47:05 AM »
Hi guys, i'm currently doing a project bike, it's a 1977 Honda CB550K3. I had the baffles of the stock 4 into 4 exhaust removed and I would be using UNI Foam Air Filter Pods, 38mm, PK3 model.
Here is a listing of information for the stock 1977 HONDA CB550K3 Keihin type PD46A carburetors:
Carburetor:  PD46A
Main Jet Size:  90
Air Jet Size:  130
Slow Jet Size:  38
Slow Air Jet Size:  150
Main Jet Needle:  E2349F
Needle Setting:  3rd Groove
What jettings and settings would you guys recommend that I use?
Offline work9to5
« Reply #53 on: December 14, 2015, 11:37:31 AM »
hey guys, I'm wondering if anyone has ever jetted these pd's for open headers and pods before and can give me a reference number as to which main jet/set up they're using. I've tired 100's (good idle, any amount of throttle twist kills bike), 115's (some back fire on idle, wouldn't drive smoothly, bike would jerk forward a bit at certain points or die). Any help appreciated.
Offline Trad
« Reply #54 on: December 14, 2015, 01:08:19 PM »
^^^110 mains and adjust the needle clip. The needle position will make the biggest difference.
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
Offline work9to5
« Reply #55 on: December 15, 2015, 12:45:11 AM »
What needle clip position do you recommend? You've used 110 with success before with open 4to4 headers and pods? I was thinking I would need to go 120 or higher.
