Bumping this one back up.
I'll be at this point soon and want to gather more info. Here's some more detailed specs on my engine, too:
CB650 cam
1.39 exh. lobe 1.40 in.
1.110 base circle 1.110
0.280 lift 0.293
I'm gaining some lift (.021 on the intake and .028 on the exhaust). With 1.1:1 rocker arm ratio, the CB650 cam has .322 intake and .308 exhaust lift at the cam.
It also has about 8 degrees more duration than the stock 550 cam, so that would be approx. 248* int. and 253* exh.
This cam is similar to "hot street" cams that were sold my Yoshi, Action Four, etc. back in the day.
Engine has been bored out 1.00mm, which will increase displacement from 544cc to 563cc, about a 3.5% increase.
Head has been ported and polished, match ported manifolds, etc.
Exhaust is a vintage, new old stock Jardine 4-into-1 with equal length runners of approx. 27", a 10" collector and a 19" muffler/baffle. Overall length, when assembled, of approx. ~54-55".
In addition to the stock jets, I have:
90, 95, 100, 105, 110, 112.5, 115 and 120 mains.
