Author Topic: rear brake hub 72 cb500  (Read 812 times)
72500john
« on: November 24, 2011, 06:27:55 PM »
pulled apart my rear wheel to do some cleaning/painting. on the rear brake hub there is a groove that looks like it would fit an oring/seal. the parts book does not show one from what i see. should there be one there. it would be on the outer diameter of the hub.
Offline Danno
Re: rear brake hub 72 cb500
« Reply #1 on: November 24, 2011, 07:09:47 PM »
I believe that is a dust groove john and no there would not be an O ring in it it is so the dust does not lock the hub to the drum
Offline fastbroshi
  • Puppet
« Reply #2 on: November 24, 2011, 11:13:40 PM »
Sure you're not talking about the opposite side?  There's a couple there.
Just call me Timmaaaaay!!!
« Reply #3 on: November 25, 2011, 12:53:19 AM »
if its on the brake backing plate side it just looks like that,,if its as per fastbroshis posted pic you can run without it ok.
