Author Topic: What's the trick to sealing the cylinder head side covers? leaking oil  (Read 1503 times)
Offline eworth
Hello,
Just installed my ported head and CB650 cam in my 77CB550.   Definately more fun!!   ;D ;D ;D
Problem is that my cylinder head side covers are leaking.   What's the secret?  I installed new o-rings and tightened the $#@% out of the side cover screw.
What am I forgetting to do?
Thanks in advance,
Mark
Offline luap
  • LAWL
Re: What's the trick to sealing the cylinder head side covers? leaking oil
« Reply #1 on: November 25, 2011, 03:20:43 PM »
are hey seated all the way? try tapping them with a rubber hammer
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
Offline eworth
« Reply #2 on: November 25, 2011, 04:01:22 PM »
Sure thought they were but didn't tap on them.  Can try.
Online dave500
« Reply #3 on: November 25, 2011, 06:49:12 PM »
the vertical bolt that holds that holder that the end caps screw to has an aluminium washer,,remove the assembly and make sure where the thing sits on the head isnt burred,also make sure the top and bottom of that holder arent burred,clean them up if they are,,throw away the aluminuim one and put a 6mm copper washer top and bottom on that vertical bolt,,often this leaks from that bolt and not those o rings,because its all hidden you cant exactly see the leak.
Offline eworth
« Reply #4 on: November 25, 2011, 06:52:46 PM »
This information is GOLDEN !  Thanks so much.   I just thought they were a bracket to hold the side cover.  Bet I didn't cinch them tight like they should be.   I will pull the covers this weekend, clean things up.   In the meantime, I will see if I can snag up some 6mm copper washers from the hardware or local automotive store.   THANK YOU!!!!!
Mark
Online dave500
« Reply #5 on: November 25, 2011, 07:03:52 PM »
no sweat,some hastily taken blurry photos,but youll get the idea,,make sure the flat surface of that little bracket is flat,,they get bent and can be easily made flat again with a small hammer.
the left hand washers are old factory ones,the right hand is a new slim copper one,these are what you want,,if you get ones not as slim its ok so long as the hole is 6mm,cheers.
Offline eworth
« Reply #6 on: November 25, 2011, 07:10:19 PM »
Ah!!!!   OK, I see now.    Ya, I'm a  visual learner.  Thanks for the reference photos!!!!   Again , much appreciated.!!  I'll bet a dime and a donut that's my problem and not the new 0-rings.    Hey, learned something new today!!
  Thanks Dave!
Mark
Online dave500
« Reply #7 on: November 25, 2011, 07:19:15 PM »
keep your donut send me a beer,dont over do those vertical bolts,just nip it down plus some,its a shallow short thread,those brackets are left and right aswell and should have an L or R stamped on them.
Offline eworth
« Reply #8 on: November 25, 2011, 07:31:26 PM »
 ;D   10-4.   Won't over do it on the bolts.   Don't wanna break nothing.     Sure hope I get a few good days next week after taking care of the leaks to ride and make sure all is sealed up correctly.
