Author Topic: Please help..weak spark and only when letting off starter  (Read 8558 times)
Offline AndyJ
« on: November 26, 2011, 07:32:16 AM »
Hi guys and gals,
New to the forums, made long intro yesterday.
I'm hoping someone can help/shed some light for me.  I purchased a 77 CB750K a couple months ago, it was in fair to poor condition cosmetically but ran strong, I rode it 220 miles the day I purchased it.
Since then I have completely disassembled the bike had the frame powdercoated and refinished the engine externally, cleaned the carbs, and basically got it all back together a week ago.
Very long story short; have spark but only when letting of the starter, she fired a few times and has backfired several times. New battery, plugs, and filed all metal grounding surfaces including the frame.
I've searched here for a remedy and have looked at the points they seem ok,but what has me is that it ran perfectly fine before I disassembled the bike and now she won't start at all.
Any suggestions or personal experience would be greatly appreciated.
Also, already checked the kill switch its good, and I have the correct wires going to the correct coils.
Wires and caps all measure 2.7-3.5 ohms, couldn't get a good read from the coils.
Starter solenoid is bad so I'm using a screwdriver across the top of it to crank the bike, would this cause a faulty spark??
Thanks so much,
Andy
1977 Honda CB750K café-brat (For Sale)
1966 Triumph TR6 Trophy Bobber (Gone never Forgotten)
1968 BMW R69S
Offline Spanner 1
Re: Please help..weak spark and only when letting off starter
« Reply #1 on: November 26, 2011, 07:43:50 AM »
Is the Red wire ( to the fuse box ) on the wrong terminal of the solenoid ?
Offline tlbranth
« Reply #2 on: November 26, 2011, 09:36:02 AM »
It sounds like maybe a weak battery or a bad battery connection. Have you tried jumping it from a car battery?
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Online grcamna2
« Reply #3 on: November 26, 2011, 03:51:52 PM »
Check to make sure that your coil brackets are nicely grounded to the frame along w/ all the other frame to harness ground straps... & +1 on the battery condition.
« Reply #4 on: November 26, 2011, 04:08:14 PM »
2.7-3.5 ohms sounds wrong,the caps should measure about 5000 ohms.
Offline AndyJ
« Reply #5 on: November 26, 2011, 06:14:59 PM »
Ok, I switched the connections on the solenoid and still nothing, then I connected the battery up to my car with some jumper cables let it crank for about 10 seconds and then VROOM she fired up, idle was a bit rough and died out after a few minutes when bowls emptied out (tank was off).
What still has me scratching my head is that it didn't start until the point where I was removing the screwdriver essentially letting off of the starter, and the four or five times after that it was the same way...cranks and cranks and cranks and fires the second I let off the starter.  Any other ideas or insight on what the culprit may be?  When I purchased the bike one of the things that I remember clearly and even bragged about to my wife and Dad was that the bike always started the instant you tap the starter button, it wouldn't even crank over it would just be running instantly, now that I've disassembled and reassembled everything it's just not the same including the fact that my solenoid is no good just clicking.
Thanks again for all your help and input.
Something else I failed to mention is that these coils are definitely not for this bike neither are the wires and caps, so the way they're mounted/grounded is a bit odd, I'm only using one mounting bracket and have both coils mounted in the same location. No strap or back coil mount, these things were zip tied on when I bought the bike and again it ran good.
Andy
1968 BMW R69S
Online scottly
« Reply #6 on: November 26, 2011, 06:28:00 PM »
So the only way you can crank the motor over is to short across the big solenoid terminals with a screwdriver? Even with the battery being jumped?
Online scottly
« Reply #7 on: November 26, 2011, 06:33:41 PM »
Andy
The stock wiring harness is grounded under one of the coil mounting bolts. There should be a green wire with an eyelet on it in that area. It MUST have a good connection to the frame.
Offline Tews19
  • I am no
« Reply #8 on: November 26, 2011, 07:15:48 PM »
I am not sure if this is 100 precent true, but I was informed never to jump a bike from a car. Can reak havoc on the electricals on the bike and fry the rectifier... I may be wrong though.
Is the battery a self filling one? One where you have to put in the acid yourself? If so, you usually have to fully charge before trying to use. If you use before fully charge it can damage the battery
« Last Edit: November 26, 2011, 07:17:51 PM by Tews19 »
1970 Honda CB750 survivor.
Online grcamna2
« Reply #9 on: November 26, 2011, 07:17:45 PM »
Make sure your coils are solidly mounted & grounded to the frame...it's important for a hot spark.When frames are painted/powder coated the old connections that used to be good grounds are not there anymore.They must have bare metal contact on the frame between all the ground connections because your frame assembly is used as a common ground for all of them & they really do need to have that common connection.
It will be necessary to get the correct coil bracket w/ correct coils & plug caps for your 77' CB750K...Ebay has a few & you can get the complete set...or try this forum "parts for sale".
« Last Edit: November 26, 2011, 07:20:51 PM by grcamna2 »
Offline AndyJ
« Reply #10 on: November 27, 2011, 09:26:28 PM »
Thanks for all the comments.
The battery is a new maintenance free gel battery, it had plenty of cranking amps but did wear down pretty quick. The bike started for the first time when I had jumped it from my car and about 4 times shortly after that without the jump while it was warm. Now it won't start again. I did make sure to completely file the Powdercoating of off the frame where the coils mount, I have bare metal and even filed all contact points on the coils and aluminum bracket and also made sure to connect the green ground wire. The only diffence between before and now is that both coils were mounted separately to each bracket and now they are mounted together on only one bracket, would this make a difference?
Wen I had the jumper cables on it still only clicked at the solenoid I'm assuming it's no good, same thing after reversing connections on it.
Thanks again for all the input and help. Since I'm on a budget I didn't want to spend another penny on getting it running so I'm hoping to figure this out as is... Thanks again!
Andy
1968 BMW R69S
Online grcamna2
« Reply #11 on: November 28, 2011, 06:00:20 AM »
It's tough to fix a 35+ year old motorcycle w/ just "pennies";these Vintage Honda's are very tough & durable & they were Originally built to last.
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #12 on: November 28, 2011, 07:32:44 AM »
You have me thinking on this one.  I have experienced the spark at the moment the starter button is released also.  Could this be the collapsing field in the coil being initiated by the removal of the power to the coils?  If that is the case, I would suspect a grounded condenser, points not having continuity, or something amiss in the wires you reinstalled for the ignition.
Offline crazypj
  • I'm brill, me
« Reply #13 on: November 28, 2011, 09:29:10 AM »
Re-do all the frame grounds, at least 1 engine mounting plate (you did remove paint before re-fitting electrical connectors?)
Get a new battery, (check voltage when it's cranking, you will probably find it's dropping too low)
Offline Spanner 1
« Reply #14 on: November 28, 2011, 03:15:38 PM »
Rigid +1.... the point wires ( Blue and Yellow ) are shorted, 'prolly attached wrong @ the points; insulator washers misplaced. Result would be the coils 'on' all the time and the instant the keyswitch is turned 'off' the collapse in the coils produces a spark, just like opening the points  ;)
Offline AndyJ
« Reply #15 on: December 08, 2011, 12:55:10 PM »
Quick update and "thanks" to all the suggestions.
I installed new coils, new points, new NGK caps, new condensers and a new starter solenoid, and already had new spark plugs.
After all that, I had a stronger spark but get this....still only when letting off the starter button. Not to mention that it cranks fairly slow and clicks at the same time but the ole screwdriver method still cranks it over very fast. Either way I'm only getting it to spark or fire when letting off the starter.
I've also figured out that the choke was not closing all the way (had filters off). So after manually closing the butterfly valves and a few fast cranks with the screwdriver it did start up, but it's not easy starting unless that is by the kick starter.
With choke closed all the way she'll start right up on the first kick!
Has anyone ever converted a cable choke to a manual lever type, perhaps by drilling and installing a lever??
Thanks again guys for all your help.
Andy
1968 BMW R69S
Offline tlbranth
« Reply #16 on: December 08, 2011, 02:01:54 PM »
Andy, have you had your battery load -tested? They'll check it for free at most car-parts places like Napa.
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline crazypj
  • I'm brill, me
« Reply #17 on: December 08, 2011, 05:12:09 PM »
Andy
 Stop messing about and get a new battery.
 The underlined part is a common sign when battery can't put out enough amps for starter and ignition.
 You could do an amp draw on starter cable (measuring points at 19.1" on 8 gauge cable 'shunt' and measure in millivolts)
« Last Edit: December 08, 2011, 05:15:19 PM by crazypj »
Offline tlbranth
« Reply #18 on: December 08, 2011, 05:39:29 PM »
Andy
Well Crazy, batteries aren't cheap. But a load test on the thing would indicate its condition. As I suggested earlier though, a simpler thing is to hook up a car battery and see how it does. Done it lots of times. Don't see any reason it'd hurt the bike, unless you hooked it up backwards. 12volts is 12 volts.
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline AndyJ
« Reply #19 on: December 08, 2011, 06:33:09 PM »
Thanks for the input guys, but as stated in my original post I had already purchased a new battery. It's the sealed, maintenance free type.
Why will it crank fast with a screw driver across the solenoid posts but slow and clicks when using the starter button after installing a new solenoid?
After all this I'll probably end up primarily kick starting it since it does start right up that way, plus it's way cooler :)
1968 BMW R69S
Offline onepieceatatime
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline crazypj
  • I'm brill, me
« Reply #21 on: December 08, 2011, 10:04:27 PM »
Faulty solenoid is the only other reason.
 Remove cable to starter and connect voltmeter in there
check it;s getting full battery voltage on output side of solenoid.
 I had forgotten that the contactors burn away.
 The solenoid still operates fine but the stopper inside prevents full contact
It is possible to take them apart and flip the moving copper contactor (may ned to unsolder the very fine control wires)
I've done it a few times for people, gets a few months~years extra use
Offline faux fiddy
  • bike in a box
« Reply #22 on: December 15, 2011, 03:31:53 AM »
Just a thought..Not sure on the 750, but other bikes have the starter and horn pushbuttons grounding directly to the controls -> handlebars/cables -> frame/motor.  Cleaning up any places where this circuit might be crusty might make a difference.
« Last Edit: December 15, 2011, 03:35:38 AM by fiddy of industry »
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline Spanner 1
« Reply #23 on: December 15, 2011, 09:19:12 AM »
Wrong coils !!!!!..... the 'old' set-up worked as the poor ground connection ( before you worked on the bike, paint etc. ) ADDED impedance to the coil primaries taking them up to somewhere nearer the stock 5 ohms.... I bet they are actually under 1 ohm coils ( later sportbike, electronic ign. ) and will not produce spark while the starter is demanding it's amperage.
Swing them by their H.T. leads in a rapid circle above your head and release . Enjoy the splash as they enter the lake water.... ;) ;D >:( ;D ???..... now start over with new/used 5 ohm coils  ;)
Offline wrenchmuch
« Reply #24 on: December 15, 2011, 10:45:38 AM »
I don't know what impedance your coils are . The symptoms you describe point to a drop in voltage in the harness between the battery and the coils . As suggested before confirm that the battery is in good shape ( I know its new but there still may be an issue ) . Get it tested and then charge it over night out of the bike . After resting for a few hours a fully charged lead acid in good shape should read 12.6 - 12.75 volts ( gel 12.9 - 13 ) . 12.5 - 12.55 ( 12.6 gel ) is only 80 % charged . Once the battery is confirmed as good you can probe the harness . Put the battery in the bike and turn the key on . I'd disconnect the lights and coils to reduce load on the battery . Use a meter and connect negative lead to battery negative . Connect positive to battery positive and note voltage . you can now move the positive test lead to positive terminals all over the bike and test them one by one . Ideally you will see the same voltage at the + wire connected to coils as you will at the battery . If there's a big difference then there's a bad connection . Kill switch , key switch , bullet connectors can all be culprits . The harness is 30+ years old now and oxidation in connections can cause all sorts of trouble . Resistance in connections causes heat as well melting insulation . Old fuse holders oxidize and can cause the fuse in them to fail from heat (melts the solder in the fuse . Just pulling connections apart during the re build could have caused this problem .
Good luck
Mike
CB750K1
CB750K4
