Author Topic: What caused failure rectifier 350F  (Read 1681 times)
« on: November 30, 2011, 10:36:00 AM »
A friend phoned he had some smoke coming from under the left sidepanel of his 350F.
He reported some burned wires but fuse is still good. IF it is a damaged rectifier, what has caused this?
What alternatives are there for a substitute rectifier?
And what needs to be checked before mounting one?
Many thanks.
Re: What caused failure rectifier 350F
« Reply #1 on: November 30, 2011, 10:45:53 AM »
Many thanks.
It is not common, but rectifiers do fail just because. Age, etc.
There is a way to test them with a meter. But its also obvious. If the wires on the lead to the rectifier are fried, or if the paint on the fins of the recitifer is bubbled anywhere, the rectumfier is shot.
You need more comments from those that know however, for your questions. I'm just being nosy.
There are solid state rectifiers out there, many people like them. Just google the topic.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #2 on: November 30, 2011, 10:54:26 AM »
Installing the battery backwards or connecting jumper cables wrong can also cause the magic smoke to leak out.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
« Reply #3 on: November 30, 2011, 11:41:22 AM »
theres a few rectifier/regulator threads here,heres a recent one.
http://forums.sohc4.net/index.php?topic=99006.0
Offline hoodellyhoo
  • CB350F
« Reply #4 on: November 30, 2011, 04:57:33 PM »
I know the rectifier on my 350 got very hot when my dad rode it with a shorting-out kill switch. The paint had bubbled but it still tested fine. I fixed the short and all was well again.
« Reply #5 on: November 30, 2011, 05:02:53 PM »
Well that puts the lie to my bubbled paint observation. I should probably say, if the paint is bubbled it got real hot, and it may or may not have failed.  :D
