Author Topic: 'reload' shocks  (Read 1488 times)
Offline phil71
'reload' shocks
« on: November 30, 2011, 03:35:31 PM »
I have an old CL90 and the back shocks are shot. The springs are fine, but they don't damp the ride at all anymore. I can retrofit other shocks, but the originals are sort of singular in their look, and I'd like to keep them. Looking at this diagram, the cartridge is seperate, do you think I could re-seal and fill it with oil?
Re: 'reload' shocks
« Reply #1 on: November 30, 2011, 05:55:13 PM »
Can you still buy the seals Phil.? That will be the main thing as well as the oil, that needs replacing...
Offline phil71
Re: 'reload' shocks
« Reply #2 on: November 30, 2011, 08:04:52 PM »
I have my doubts.. But looking at that photo, the shock absorber part looks like one unit. I'm thinking of drilling and tapping a hole and putting some oil in , plugging with an Allen screw.. Only the bushings seem available from dealers.
Offline BAchvytrk
Re: 'reload' shocks
« Reply #3 on: November 30, 2011, 08:20:38 PM »
if you can get the old seal out, take it to a bearing supply store, or measure the id od and thickness, should be able to get a seal that way.
71 FLH
74 Ironhead
1965 305
1971 SL350
1974 750k
1975 550F
1977 550K
1980 KZ440
1980 CB900F
Re: 'reload' shocks
« Reply #4 on: November 30, 2011, 10:02:05 PM »
I agree, nothing will work for long without new seals...
    • http://forums.sohc4.net/index.php?PHPSESSID=il7j2f9qnscj27ocom4ve691e7&/topic,60973.0.html
Re: 'reload' shocks
« Reply #5 on: December 01, 2011, 01:49:51 AM »
i have fillt atf oil on my dampers on the 400 f ...but are it pitted or rusty..it vill eat the sealing..on my yamaha fs1(moped)i just pumped  a littel grease in.and veldet the hole.
many mopeds have not real oil dæmpers..but if speeds is over 70 kmt..it can be a problem...
some have build car gas" shocks"last pich..think it can be done on cd and cl modells
but there are fine kopies from thailand..so thek it before a lot of work
and sorry for my english..
« Last Edit: December 01, 2011, 02:08:19 AM by strynboen »
