Author Topic: Soda Blaster Leaf Blower - Will It Work?  (Read 8685 times)
Offline chewbacca5000
  • I polish covers!
« on: December 02, 2011, 08:27:57 AM »
For the longest time I have wanted a really good air compressor that puts out 10+ SCFM to do soda blasting and other types of blasting, but can't do it do to no 220v in my house.  After recently installing insulation in the attic of my house I cam across a video on Youtube.com that used a leaf blow for blown in insulation Attic insulation with leaf blower
This thing shoots insulation 30+ feet at speeds of 200+ miles per hour at 100s of cfm.  Why can't I have a gravity feed attachment, or use the vac like in the video to shoot soda at 200 MPH?  I'd really like to get some input on this one.  Thanks!
Re: Soda Blaster Leaf Blower - Will It Work?
« Reply #1 on: December 02, 2011, 08:33:33 AM »
What type of "blower" is that insulation machine ? I wonder if it is a hydraulic pump of some type ?!
  • I polish covers!
« Reply #2 on: December 02, 2011, 08:41:19 AM »
It looks like a regular blower vac, with the safety grate removed and something jammed in the safety slot to keep it running.  There would be no need to do that with soda as the soda will go through the grate.  Put a hopper on top and get a smaller opening to control the soda a little better and it just might work.
Online Don R
« Reply #3 on: December 02, 2011, 08:54:20 AM »
I don't think so but,,,, give it a try you may need to funnel the air down to create a jet and fed the soda in close to the nozzle. don't run the soda through the blower, it will eat it up.
  • I polish covers!
« Reply #4 on: December 02, 2011, 08:59:48 AM »
Yeah that was my thoughts exactly running the soda through the blower will eat up the motor.  Good idea on the jets!  Thanks!
Offline heffay
« Reply #5 on: December 02, 2011, 10:10:44 AM »
Why do you think you need an alcohol burning V8 compressor just to run a soda blaster?  I have no problem using what I made and it takes stuff off just fine, and I've not heard others complaining of low power compressors.  Now, if you were bead blasting or sand blasting, I could understand the need for a big compressor.
  • I polish covers!
« Reply #6 on: December 02, 2011, 10:18:54 AM »
We'll I have used a 10lbs Harbor Freight Soda Blaster with a 5.9 cfm compressor and it only seemed to work half the time.  Did a good job for stripping aluminum parts, but not so good at removing frame paint.  With 100s of cfm from an electric leaf blower just makes sense that it will work that much better. That and I really like backyard invention type stuff.
What did you make I'd like to see it.
Offline heffay
« Reply #7 on: December 02, 2011, 10:40:39 AM »
Ya, I got more stuck on the giant compressor issue.  I guess you're really talking about a leaf blower, and I should stick to the topic at hand.
I say turn the blower so the nozzle is vertical, dump a box of soda in, aim, pull the trigger.   ;D
  • I polish covers!
« Reply #8 on: December 02, 2011, 10:42:31 AM »
Worth a shot.
Offline heffay
« Reply #9 on: December 02, 2011, 10:57:13 AM »
seriously though, i think its an awesome idea.
maybe even try a shop vac/blower, you'd have your soda reservoir right there.  you'd have to re-route your intake to the inside of the dust bin, obviously.
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #10 on: December 02, 2011, 11:10:45 AM »
I am voting no.  Too low of pressure at too much volume.  Like trying to use a sand blaster with a large nozzle, it just doesn't have the velocity to create much impact force on the material.  Give it a shot, but please, post vids on youtube so we can see the white cloud created.  Nice pussy by the way Heffay.
Offline heffay
« Reply #11 on: December 02, 2011, 11:13:19 AM »
I would think he intends to take the hose diameter down a notch or two... or 100  ;)
oh, and thanks.   :D
Offline Pecantree
« Reply #12 on: December 02, 2011, 11:15:35 AM »
Do It! DO It! I think this is a great idea! Let us know how this works!
You could combine it with the DIY leaf blower hovercraft.
Offline gecko672
« Reply #13 on: December 02, 2011, 11:51:55 AM »
I have a feeling that once you make the nozzle smaller to increase the velocity the the air  will back up and escape thru the motor/fan without a one way valve. and you wont really get the velocity of air you expect.
A leaf blower isnt designed to create the pressure you might need. But I think it would make a fantastic video clip and  f' the naysayers...me included.
Do it.
CB750 1971 K1
bollingball
« Reply #14 on: December 02, 2011, 12:06:42 PM »
I say try it. But a small air compressor would serve you a lot better it will run longer due to the small tank.I think the motor on that shop vac will not last long if you ckoke it down enough to do any good. Then use the shop vac for dust control with a sheetrock dust filter For a test see how long it takes to blow up your car tire with the vac ;) I think choked to the size of a pencil you will be lucky to blow soda at 15-20 psi If at all. But we won't know if you don't try Good luck
Offline camelman
  • Man... Myth... Legend
« Reply #15 on: December 02, 2011, 01:21:44 PM »
You need a pressure ratio of 1.8:1 to get the velocities you need to achieve mach one, which is what a typical media blaster will operate at.  Actually, you'll just get to mach 1 and then you'll create a normal shock that will drastically reduce the velocty and pressure of the flow, but that will happen at the exit of the nozzle of the media blaster (hence the loud noise when you vent high pressure air).
However, as long as you introduce the soda into the stream before you exit the tube (end of the media blaster), then you will accelerate your soda to a very high velocity.  I believe mach 1 is about 650 mph at sea level, although the conditions inside the media blaster will be much higher pressure and lower temp.  Those two changes might balance out, so you could see 650 mph air velocity inside the media blaster before it shocks and loses velocity and pressure.  That is much higher than the 200 mph you'll get from your leaf blower.  Remember, "Kinetic Energy" = 1/2*Mass*Velocity^2, so velocity plays a large role in the effect of media blasting.
You would need a leaf blower with a high pressure ratio capability to achieve the same results, but I don't think the engine or the fan are designed for that.  Best bet is to use a proper media blaster with sufficient flow and pressure.
FYI, if you release air above 26 psi in direct sunlight (i.e. air from a tire, liquid air in a can, compressor air), and hold the air source close to where a shaddow can be cast, then you'll see the shock waves in the shaddow since their formation alters the direction of incomming light.
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
  • I polish covers!
« Reply #16 on: December 02, 2011, 02:14:38 PM »
We'll after a short test where I reduced cut a soda bottle in half and put in over the leaf blower and poured some baking powder in the nay sayers have it. Didn't strip paint.  Maybe if I used actual baking soda or media it might have made a difference, but I doubt it.
Camelman I am not sure what the 1.8:1 ratio is and how it works in an air compressor.  Or how your are getting 650 miles per hour.  What air compressor specs will generate 650 MPH media impact.  Also, will bigger air tanks help with meida / soda blasting. Thanks!
bollingball
« Reply #17 on: December 02, 2011, 02:46:09 PM »
1-1/2 to 2hp 20 gal tank under $200 will work fine for what you want
  • I polish covers!
« Reply #18 on: December 02, 2011, 02:48:18 PM »
Thanks Ken!
bollingball
« Reply #19 on: December 02, 2011, 03:02:08 PM »
Sorry I just saw you were talking about a leaf blower not a shop vac but I think the outcome would be close to the same. If using inside you will want the vac. with sheet rock filter real dusty
                               Ken
Offline gecko672
« Reply #20 on: December 02, 2011, 04:41:53 PM »
its been way to long since I was at school but pushing the air through a tube then reducing the diameter of the tube speeds the air up, there are formulas but you trade pressure for velocity  as it passes through.  you double velocity and 1/2 pressure or something like that....so depending on the pressure and the diameter of the nozzle you could reach velocity of 650MPH... is it Venturi effect?
the trouble with the leaf blower is you cant maintain or build the pressure before it passes through the nozzle..which is what a compressor does.
CB750 1971 K1
Offline FuZZie
« Reply #21 on: December 02, 2011, 05:23:49 PM »
I don't know if it'll work or not, but you have to get a vid for us if you try it.  ???
Offline WarwickE36
« Reply #22 on: December 02, 2011, 06:12:41 PM »
I thought this was a joke ...  then i remembered when my friend used a leaf blower to clean his snowmobile....  stranger things have happened.
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline lone*X
« Reply #23 on: December 02, 2011, 06:13:23 PM »
Like it has been said, you don't need a big compressor.  You need the right media.  Over the counter soda is too fine for stripping hard paint like came on these frames.  Commercial blasting media is made in several grades, the coarser it is the more aggressive it will be on paint.  The local Harbor Freight sells it in about three grades if memory serves me right.  Comes in 50 lb bags.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline wedoo2
« Reply #24 on: December 02, 2011, 06:17:28 PM »
That went by without a peep.  Very funny. :D
Some days the sun is too loud.
