Author Topic: exhaust collar woes  (Read 863 times)
Offline octagon
exhaust collar woes
« on: December 03, 2011, 09:46:41 AM »
i'm trying to put a rc engineering exhaust on my 76 750k. the headers are set up to use split collars, which i have, but they are about 1 15/32 inside diameter, and the outside diameter of the headers is more like 1 17/32. anybody else run into this by any chance? these collars came off a 77 hondamatic.
also have a junk set of headers with k type ends but would like to avoid cutting and welding.
Offline octagon
Re: exhaust collar woes
« Reply #1 on: December 03, 2011, 02:48:16 PM »
ps this is what i'm working with also:
http://forums.sohc4.net/index.php?topic=70360.0
will post a wanted ad for some mac collars - any other ideas?
Offline octagon
« Reply #2 on: December 03, 2011, 03:15:54 PM »
another ps - also contacted mac by email - they say they get back to you within 72 hours
« Reply #3 on: December 04, 2011, 08:30:49 AM »
 some muffler shops may be able to make them.
 Can also be machined, then split... too bad you are not near me..
Offline octagon
« Reply #4 on: December 04, 2011, 12:17:36 PM »
maybe the mac people have them - other thought was to grind down the inside of the stock collars. this would leave larger gap at the splits though. i wonder about doing that anyway and adding a washer to bridge the gaps. probably there are shims out there that would work as washers.
