Author Topic: Sorcerer and Atchison, Topeka and Santa Fe to be restored  (Read 520720 times)
Online Don R
Re: Sorcerer and Atchison, Topeka and Santa Fe to be restored
« Reply #3225 on: June 08, 2024, 03:34:16 PM »
 Thanks Robbie, what I was thinking, a friend had a 392 that Garlits helped them put the new blower on at Cordova, they promptly knocked the side out of a cylinder after forgetting to back it off. The piston stayed in the hole, and you could see it going up and down.
Online Don R
« Reply #3226 on: June 08, 2024, 03:34:56 PM »
 Sorcerer made noise, I saw it on F/B reels.
https://www.facebook.com/reel/482975887736260
« Reply #3227 on: June 08, 2024, 04:17:11 PM »
And what a noise it is!
  • Moderator
« Reply #3228 on: June 09, 2024, 02:36:52 AM »
Thanks for posting Don, well done you.
Sam.
Offline CycleRanger
  • No comment about being an
« Reply #3229 on: June 09, 2024, 06:08:09 AM »
What an incredible moment!  :)
Congrats!
Offline kap384@telus.net
« Reply #3230 on: June 09, 2024, 08:11:52 AM »
Incredible to see!
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda CB400F Supersport
1977 Honda CB750F2 Supersport
1978 Honda XL100
1979 Honda CBX Supersport
1982 Honda VF750S Sabre - Adventure Bike modified
1983 Honda CX650T
1995 Honda VFR750
2016 Honda CRF1000L Africa Twin
2015 KTM 200 XC-W
1963 Suzuki T10
My 1977 CB750F restoration - http://forums.sohc4.net/index.php?topic=66779.0
My 1975 CB400F restoration -
http://forums.sohc4.net/index.php?topic=145196.msg1651779#msg1651779
'More Stock Than Not' thread - http://forums.sohc4.net/index.php?topic=90807.500
My CT70 Resurrection - http://forums.sohc4.net/index.php?topic=145221.0
Best Motorcycle Tool Ever - https://www.engduro.com
Online Don R
« Reply #3231 on: June 09, 2024, 10:40:37 AM »
 I know there are guys here that were a part of one or all of the RC projects. You should all be proud, this is just the first result of your input of knowledge and parts.
Offline NitroHunter
  • Radical Street / Strip Turbo
  • A man's motorcycle is a reflection of the man
« Reply #3232 on: June 09, 2024, 11:19:21 AM »
The initial fire up was an awesome success! Great job to everyone involved!
A note of interest here, for this first fire it used two separate fuel related systems, one being 41 years old, and one being a new addition. And the nitro system hasn't even come into play yet.
As you have seen on TV, the starting line procedure for a Top Fuel car is pretty strait forward: open the injector butterflies, squirt in a shot of gasoline which (thanks to gravity) runs down into the blower, close the injector blades, open the fuel pump shutoff, and hit the starter. Pull the mag ground clips and things happen. In those few seconds the engine runs on gasoline, the fuel pump has nitro pumped into the injector lines and you can hear the difference in the running sound as it takes over.
BUT the Sorcerer has its blower mounted upside down with the intake manifold above, and the injector underneath, it's defying gravity now, so how to get that initial charge of gasoline in for the lite off? And how can it stay running for an extended warmup without running on nitro?
Here is where the genius of Sr, Byron, and their many collaborators shows yet again.
They incorporated a very small pressurized gasoline section into the frame, on spinning the starter the valve is opened and gas squirted through the injector lines for firing, just enough for the engines to start and nitro to take over. Very clever.
But now we're looking at the initial fireup of a 41 year old machine that's been through 12 years of countless manhours of restoration, everything needs to be checked out, the brief run time provided by its gasoline starting circuit puts very little heat into the head, and quite frankly everyone's a little apprehensive of that first nitro pop.
So a plan was devised to run the engines on alcohol for an extended time, it's quite simple but was a real challenge to plumb in this complex application.
For a blown car we connect a small flexible hose line between the top of the blower and the base of the injector, the other end is just dropped into an alcohol jug. Once started the engine's vacuum sucks enough fuel to run at a fast idle, allowing the motor to be warmed up without burning that $40 a gallon nectar of the gods. It also allows fuel to lubricate the blower stripping which is a big deal.
Robert Prayther who did the fuel system plumbing seen earlier, did the mental and physical gymnastics to actually FIND this spot and attach a line there. The closer you REALLY look at the Sorcerer the more challenging this becomes. Good job man. The complexity of this machine is mind boggling.
Everyone that participated along the way I'd say we all have a reason to be proud.
Robbie the NitroHunter                      Fuel Coupe Hired Gun                  NHRA T/F 640
DRAGBIKE USA XH/MB Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=127179.0;attach=332735
DRAGBIKE USA XH/SS Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=63940.0;attach=103300
Young mans glory days in the lanes: http://forums.sohc4.net/index.php?action=dlattach;topic=45685.0;attach=66341
  • Moderator
« Reply #3233 on: June 09, 2024, 12:32:52 PM »
Awesome write up Robbie, it's you who should be proud. Your knowledge working with Top Fuel motors has not gone unnoticed, we all thank you Sir.
Sam.
« Reply #3234 on: June 10, 2024, 06:30:09 AM »
One word... WOW!
« Reply #3235 on: June 11, 2024, 09:45:19 AM »
I can't stop smiling. It's like the 750 King Rides Again! :D
Offline Old Scrambler
« Reply #3236 on: June 11, 2024, 04:53:56 PM »
I had a Dream...........Oh Yeah ;D ;D ;D ;D
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #3237 on: June 12, 2024, 06:54:26 PM »
First look at this, I’m all giddy over here! Great job guys, CONGRATS!
Offline 1080
« Reply #3238 on: June 15, 2024, 09:18:10 PM »
 That put a smile on my face hearing it. It sounds Sweeet. :)
Offline dusterdude
« Reply #3239 on: June 16, 2024, 07:42:19 AM »
I hope you guys dont mind if i hijack this a little bit,i found this when cleaning a little while ago.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline dusterdude
« Reply #3240 on: June 16, 2024, 07:42:38 AM »
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Online Don R
« Reply #3241 on: June 20, 2024, 09:05:10 PM »
 I'm getting facebook hints that a startup of ATS&F is coming soon.
  • Moderator
« Reply #3242 on: June 25, 2024, 03:14:39 AM »
Very soon we all hope Don.
Online Don R
« Reply #3243 on: July 12, 2024, 09:55:29 AM »
  The ATS&F has made noise! There's a video link on RC Jr's facebook page! It was posted 2 hours ago.
« Last Edit: July 12, 2024, 09:59:31 AM by Don R »
Online Don R
« Reply #3245 on: July 12, 2024, 11:20:58 AM »
NOISE is a wonderfull thing :) :) :)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
  • Moderator
« Reply #3246 on: July 12, 2024, 12:07:48 PM »
https://www.facebook.com/groups/451231164982012
Thanks for posting Don, I fell asleep and didn't see it for a few hours, thanks for putting it here for those that are on Facebook and can see it, even if it was only for a few seconds.
« Reply #3247 on: July 13, 2024, 03:27:55 PM »
It's a good start. ;)
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #3248 on: July 13, 2024, 04:50:38 PM »
 8)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline dusterdude
« Reply #3249 on: July 14, 2024, 03:34:41 AM »
Would someone ask russ to post these things aomewhere other than facebook?perhaps youtube.
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
