Hi all, first post here. I've got a 1980 cb750c project that I was planning on using parts of later model sport bikes.
This morning I went out into the garage and put a penny in the parts fund jug. Now there are two in there. I hope they like each other, because if they don't start getting "busy" I'm not getting any parts soon.
I have a non running 1990 vn750. I was thinking about using the forks, trees, stem and wheel from that, until I can get a set of forks I really like.
I've found the charts for steering stem bearing sizes and compatibility. I dont think I'll have a problem getting the bearings to make it work.
I dont know how long the stems are on each bike. I have the honda one removed and I'd like to know the measurement for the vn750 before I remove it.
I've searched the net and cant find the specs anywhere, probably looking in the wrong spots--figured I'd check here before calling around.
Thanks
Report to moderator Logged
Alan F.
just the essentials
Old Timer
CB750K3 build with no end in sight
Re: need steering stem sizes
« Reply #1 on: April 05, 2010, 10:26:42 am »
Ah the search for the elusive steering stem length chart, I know it well. You'll probably have to just measure it yourself.
Check the link in my signature line for some info that may be useful.
-Alan
Free Fork Swaps and Upgrades info parked at
http://sites.google.com/site/alansdocuments/ My slow going 750K3 with swaps build
http://forums.sohc4.net/index.php?topic=46082.0--------------------------------------------------------------------------------
henry1282
Guest
« Reply #2 on: April 05, 2010, 10:29:50 am »
Thanks, I'll check em.
fiddy of industry
Time to go back through and delete a couple hundred posts so I won't be called an
Master
bike n a box
« Reply #3 on: Today at 02:21:14 am »
Modify
Remove
Shoutout to any of the mods... can this information be cut, pasted, cross refrenced, catalogued and google indexed, and stuck on sticky topics, perhaps on suspension and forks?
http://www.customfighters.com/forums/showthread.php?t=22068http://scandalon.com/2009/06/motorcycle-steering-stem-bearing-size-chart/'cuz everyone wants something different or better or bigger than stocker or adapt a run whatcha brung or ebayed on the budget,, bla bla bla..
Simple to cut and paste this all, and then we could find these and others from wherever right heres.
