Author Topic: Final driven shaft bearing removal  (Read 1061 times)
Offline jacquesleclochard
  • If Tin Can do it, you can do it!
    • Tin Can Customs
« on: December 19, 2011, 03:02:08 PM »
Hey gang. I'm almost ready to sandblast my engine, as it is close to a complete teardown. Two things are still sticking in the base: the bearing ball of the final driven shaft, and the gear shift drum. I found the removal procedure for the latter one trough the search function, but had no such luck on how to remove the bearing balls. I'm talking about part #12. Use force? Can I re-use the bearings after removal?
Offline markb
  • When I finish my current project I might be a
Re: Final driven shaft bearing removal
« Reply #1 on: December 19, 2011, 03:07:45 PM »
I just use a wooden dowel to tap it out from the right side.  It shouldn't hurt the bearing.
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
