Author Topic: 750F owners - how do you hold up the front end when changing fork seals?  (Read 4504 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
... without taking off the 4-1 header? I don't want to prop it up on the oil filter housing. The oil pan is too far back and I'm not sure I'd want to do that anyway.. There's a narrow space where the lower motor mount bolt goes - maybe an inch across - that I could fit a jack stand longways into, but at best that would be in the middle and not very stable.
Offline CB750R
  • 77 CB750F
Re: 750F owners - how do you hold up the front end when changing fork seals?
« Reply #1 on: December 20, 2011, 05:23:07 PM »
Jack stands under the pegs I think work! So does some tie down straps from the ceiling to the handlebars.
Offline Trav-i
  • Has finally become an
« Reply #2 on: December 20, 2011, 06:24:38 PM »
I've done it several ways.  I've used jack stands under the frame (but in your case that won't work), I've also used a chain hoist in the celing or tie strap from a rafter, but I think in your case I would use my other method balast.  Just put something fairly heavy on the seat as far back as it can go, it will keep the front safely off the ground.  Last time I did that I used a short heavy punching bag worked great.
Travis
Forum member #9962
1992 GL1500 Interstate
« Reply #3 on: December 21, 2011, 06:51:36 AM »
+1 on the ceiling hoist. i used 2 ratchet straps..
Offline CycleRanger
  • No comment about being an
« Reply #4 on: December 21, 2011, 07:14:18 AM »
Floor jack with a piece of 2x4 works.  Or straps from the ceiling.
I like that oil filter bolt, btw. :)
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #5 on: December 21, 2011, 11:44:24 AM »
Straps to triples from the ceiling for the win.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #6 on: December 21, 2011, 01:54:41 PM »
Jack with a piece of wood under the oil filter a dozen or more times, no issues. There's not more than a few pounds of weight at that point when sitting on the center stand. Put your hand under the oil filter, with the bike on the center stand, and lift up. This will give you an idea how little effort is required to lift from this point.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Davidov
  • 1978 CB750 F3
    • My CB750F project log
« Reply #7 on: December 21, 2011, 01:59:08 PM »
+1. Block of wood on the oil pan, and use a floor jack?
-David
« Reply #8 on: December 21, 2011, 02:02:12 PM »
Yup that's always been my point. You can put a weight like loaded saddlebags on the rear to help. Once the front wheel is off there is very little weight on the filter housing.
I like the hangem from the ceiling idea, but that restricts movement, assuming you want some. If its just fork seals, maybe you don't want any movement.
« Reply #9 on: December 21, 2011, 03:19:06 PM »
I had not considered that, a bag of concrete on the back of the seat and no other lifting means required!
TAMTF...
Wilbur
Projects:
« Reply #10 on: December 21, 2011, 04:50:46 PM »
Great! I'm good for something!  :D  I've used the saddlebags trick, as I have them, but also a toolbox bungied to the luggage rack.
Offline jtb
  • An unlikely
« Reply #11 on: December 21, 2011, 05:57:21 PM »
I use a piece of 1X4 under the pan and a bottle jack.
1977 CB750F
1985 V65 Sabre
« Reply #12 on: December 21, 2011, 06:44:38 PM »
I have done that several times. I put her on the center stand and put a bag of something on the back. When you remove the front wheel she wants to tip back anyway. If I am using my Sears Motorcycle lift, I put a jackstand  under the swingarm. The bikes are back heavy even though they look front heavy with the motor tilted forward.
Offline maxspeed140
« Reply #13 on: December 21, 2011, 07:00:41 PM »
I use a cargo ratchet. Bike on center stand. Hook one end to inside garage door handle (2 inches from ground), then hook the other end through both sides of grab bar in a loop. ratchet just until front tire is off ground.
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #14 on: December 22, 2011, 01:31:05 PM »
yep bag of concrete on back of seat while on center stand.  either that or my portable tool box.
MATT
Offline cben750f0
« Reply #15 on: December 22, 2011, 05:21:59 PM »
lol i put my heavy tool box on the back of the seat, and took the front wheel off...then it sat on the back wheel...lol
though that may not be correctly legal...lol
peace
