I've found it to be a problem with several Honda blocks.
The liners are too loose and you can't take more than 0.010" cuts
It's usually better to take around 0.006" but it then takes a long time to remove a few mm
It looks like they were trying to save time and took a deeper cut which causes liner to rotate
I've measured around 0.0007" ~0.0015" interference fit, at 'low end', liner can move when honing as block heats up.
I don't like boring stock Honda blocks for big bore kits, prefer to fit new liners first to have at least 3.25mm wall thickness when finished (0.003" interference, liners shrunk in)
LA Sleeve recommends 0.004" but I find that too tight and liners can crack when you overbore them (XS650, 800cc conversion)
Correct thing to do would be remove all the liners, have the outside copper plated then shrink them back into block.
They need clamping into position, plus, cool top of block (otherwise they tend to 'grow' as block cools evenly.)
I've made various fixtures and have a baking tray I bolt to top of block (with various adapters to hold liners down) fill it with ice cubes to chill top of block.
I found out the hard way about this stuff, combustion leak into oil-way was not a good thing at 80mph (liner 'dropped' about 0.010"
