Author Topic: Just awesome  (Read 3987 times)
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Just awesome
« Reply #25 on: January 03, 2012, 06:33:29 PM »
A dead rat (or opussum, raccoon, etc.) tends to stink up a place too. Especially when they crawl up into a wall or ceiling cavity where they can't be found nor removed...
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline krusty
Re: Just awesome
« Reply #26 on: January 03, 2012, 10:11:50 PM »
Good thing you installed a security system so soon. You may be paid a repeat visit by the lowlifes expecting to find a garage full of new tools!
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline lone*X
Re: Just awesome
« Reply #27 on: January 08, 2012, 08:52:24 PM »
I wouldn't be too hard on the old folks, they can really get set in their ways and it's hard to get them to change their minds on anything.  I would be upset with the complex management.  Sheetrock for dividing walls in a shared building?  That's asinine.  That is no security at all.  Make them buy you enough 3/4" plywood to cover that wall and screw it to the studs with 3" lag bolts.   And get it done before you replace all your tools.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Re: Just awesome
« Reply #28 on: January 10, 2012, 08:08:26 PM »
Probably plywood would be a fire code issue. But it could be covered with drywall again to retain the fire resistance.
Offline rbmgf7
  • 2>4
Re: Just awesome
« Reply #29 on: January 13, 2012, 08:22:07 PM »
They still are using a sheet of plywood to cover the hole. I kinda figured drywall was used to meet code but just one sheet? Even if a fire were to brake out on my side, it'll burn through the studs. Albeit, drywall is only fire resistant to and extent but at least cover both sides of the studs. It's doesn't do the drywall a lot of good when the stud burns away first. I expect it's just enough to meet the bare minimum standards.
I'm just trying to ride out my lease until August and hopefully by then I can find my own place. I'm freaking tired of leasing apartments. I want my own garage, damnit!
Good news is, I did get my settlement. It was just a little over what I claimed. I now have recovered nearly 90% of my tools.
