Author Topic: Will a Cb650 alternator keep up with a small radio?  (Read 1377 times)
Offline RustyStuff
  • If it aint broke, Fix it till it Is.
« on: December 27, 2011, 08:44:19 PM »
I know these bikes don't have a strong chargeing system, so I feel the need to ask.
I'm thinking about putting together a little radio setup. I've got 2 small 3" speaker/box combo's and I have a Radio that is half dead. I would have to look it up, but the radio only puts out 15W Max per side, so not much draw.
I've got a Vetter Quicksilver fairing on the 650, I think everything should fit on it.
Anyone else have a radio on there bike?
'80 CB650
Offline grcamna2
Re: Will a Cb650 alternator keep up with a small radio?
« Reply #1 on: December 28, 2011, 03:39:13 AM »
I would test the radio to see how much it draws on a good auto test battery as far as current draw.
75' CB400F/'bunch o' parts'
Offline lone*X
« Reply #2 on: December 28, 2011, 11:37:46 AM »
As long as you wire it switched and not direct (so you don't accidentally leave it on) you should have no problem.  I ran my 75 CB550K1 with a CB/AM/FM mounted in a Vetter for quite a few years and never had a problem.  One advantage the older 550 has is that the headlight is still switched.  In Texas the Always on headlight didn't show up until 76 I think.  Even then I ran at night a lot (worked graves for a looong time) and the charging system kept up while the headlight was on.  Your mileage may very, but what can it hurt to give it a try?
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline cb650
« Reply #3 on: December 28, 2011, 02:53:34 PM »
Clean up all the connections.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #4 on: December 28, 2011, 03:06:19 PM »
Keep the revs up and you'll be fine.  If you let 'er idle a lot, that's what will cause your battery to deplete.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline Hush
« Reply #5 on: December 28, 2011, 05:36:34 PM »
The CB650Z in it's 650PZ form was used as a Police patrol bike around the world, all carried R/T radios as standard equipment, it never seemed to bother the bikes charging system so I would say you should be OK.
Offline RustyStuff
« Reply #6 on: December 28, 2011, 06:38:01 PM »
Thanks for the advice.
'80 CB650
