Author Topic: CB550 separating rear cush drive from hub  (Read 4327 times)
Offline charlie27
« on: December 28, 2011, 05:52:48 PM »
Hi,
cush drive stuck in hub.  Tried hitting sprocket face with rubber mallet to loosen but no go.
suggestions welcomed
Re: CB550 separating rear cush drive from hub
« Reply #1 on: December 28, 2011, 10:12:53 PM »
youve undone that left hand thread ring nut?
Offline CoachDoc
  • 1974 CB550, 2005 GL1800, 1997 Valkyrie Standard
« Reply #2 on: December 28, 2011, 10:32:50 PM »
What Dave is saying (I'll translate from Australian) is you have to first remove the bearing retainer, which is reverse threaded. It requires some sort of home made tool to remove it, since the Honda special tool is no longer available- search this site and there are several threads about such tools. Once the bearing retainer is removed it's simple to push out the cush rubbers from the inside. Note also that there are "stakes" punched into the metal of the threads that have to be drilled out lightly in order to unscrew the reverse threaded retainer.
Here's a link to the simple tool I made to do this, and how to use it: http://forums.sohc4.net/index.php?topic=97342.0
« Last Edit: December 28, 2011, 11:17:51 PM by CoachDoc »
Offline charlie27
« Reply #3 on: December 29, 2011, 07:55:23 AM »
doesnt the sprocket carrier just push into the hub like most bikes?
I thought there would be the the tangs on the sprocket carrier and the rubber bumpers on the inside and just pushed together.
not that way?
thanks
Offline CoachDoc
« Reply #4 on: December 29, 2011, 10:23:10 AM »
Classic Honda over- engineering, Charlie, but the sprocket carrier on the 550 is indeed held in place by the threaded bearing retainer. Don't forget about drilling the staking first and the left handed threads, which is the opposite of the threading on the front hub.
« Reply #5 on: December 29, 2011, 12:27:26 PM »
that flange nut must be removed,it undoes clockwise.
    its easier and causes less damage if you have a tool like these.
  i pinched a photo here from terry in australia.
« Last Edit: December 29, 2011, 12:38:57 PM by dave500 »
Offline charlie27
« Reply #6 on: December 29, 2011, 01:43:59 PM »
ok I understand now.
thanks!!
« Reply #7 on: December 29, 2011, 02:40:10 PM »
you might try with a punch to knock it in the clockwise undo direction,it might be loose enough to come easy,you might find it has been staked with a prick punch or chisel inside those holes,youll have to drill that slightly,,ive had them come undone easy without unstaking,spray some wd40 or similar into those threads they are very fine.
