Author Topic: Oil flow direction at the filter-  (Read 1777 times)
Offline Hannibal Smith
  • 3rd Grade Dropout
« on: December 28, 2011, 05:59:45 PM »
1974 CB550-
Before I button this last bit up- I need to confirm that the flow is "OUT" the central hole (into the center of the element), and back "IN" at the lower hole (after flowing through the element to the outside), and this is at the filter/filter housing area at the front of the motor.
Follow my build "P38 Racer" in Project section
bollingball
Re: Oil flow direction at the filter-
« Reply #1 on: December 28, 2011, 09:00:12 PM »
There is a oil flow chart in the manual at the front about page 26. Looks like it flows from the outside to the center.
                                                       Ken
  • 3rd Grade Dropout
« Reply #2 on: December 29, 2011, 07:38:33 AM »
I don't have that flow chart in my Clymer manual- What manual are you referring to?
Offline lone*X
« Reply #3 on: December 29, 2011, 08:05:34 AM »
Bollingball is referring to the HONDA maintenance manuals on SOHC4 website.  You have to look closely to see the arrows depicting oil flow in the engine blowup on Page 36.  The link below takes you to the correct manual section, just page down in the .pdf until you get to page 36.
Honda's manuals are much more comprehensive than Clymer or Haynes.
http://data.sohc4.net/SM500/HSM500550_2.pdf
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
  • 3rd Grade Dropout
« Reply #4 on: December 29, 2011, 09:04:48 AM »
Thanks!!!!!!! ;D
Offline crazypj
  • I'm brill, me
« Reply #5 on: December 29, 2011, 09:09:30 AM »
Nope, comes in from the outside, flows through filter to center.
 You will severly reduce surface area flowing from center out, plus, you will never be able to see anything that should be on outside if it's inside
