Author Topic: Turbo CB650c with CV carbs, Research Phase  (Read 1401 times)
Offline ThomasD883
« on: December 28, 2011, 08:10:51 PM »
Well, my current plan is to turbo my '81 650  8) . Hardware is planned as a T2 or so turbo, ball bearing if cost permits with an intercooler and pressure relief. I've already got my CV carbs planning on a blow through setup, i believe that all i need to do is provide the vacuum signal from the turbo air inlet where i'd get the best and most accurate source, and route the fuel bowl vents to boost so it can push fuel under boost. Wide band o2 with a custom header and probably a dump pipe. Oil lines, i have heard that a scavenge pump is needed but i would like some advice on the ins and outs of this. I will be making an air manifold. Maybe a thicker head gasket to lower compression but boost will be relatively low, 5-8 psi or so. I would REALLY appreciate as much info and advice as anyone would be willing to give. This is in the planning phase and i am trying to get my ducks in a row then take my time and do this as well as possible. Thanks everybody! ;D
Diesel deeds, done dirt cheap
Offline CBJoe
Re: Turbo CB650c with CV carbs, Research Phase
« Reply #1 on: December 28, 2011, 08:43:08 PM »
Subscribed..... cant help much... but would love to see a Turbo'd CB650  ;D
Cheers, Joe
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
« Reply #2 on: December 28, 2011, 11:32:24 PM »
Gday Thomas, have a chat to member BLUE71TURBO, {Jon} Nice guy and  he should be able to help some....
http://forums.sohc4.net/index.php?action=profile;u=11266
Offline cb650
« Reply #3 on: December 29, 2011, 05:50:46 AM »
Very cool!!!!!    I read a article on the cx500 turbo that said honda was debating turboing the 650 instead as it was a proven engine design.  But decided on the cx for the water cooling.
