Author Topic: Anybody know which connector should be used ? w/ photo  (Read 2030 times)
Offline greenjeans
  • 1972 CB750K2
« on: December 29, 2011, 07:58:15 AM »
Pretty close to getting my 1969 CB750K on the road again and when cleaning off the wiring and connections, I noticed that one of my conncetors is toast.
Does anyone know if the 6 pin connector from the rectifier to the harness has a locking type connector or a non-locking one?
The one on my 75 is the locking type.  The one on the 69 appears to be non-locking, but I can't really tell as most of it has disintegrated.
The on off the '75
The one off the '69
**  Also - has anyone been able to source the white fiberglass ? insulation that is sleeved on the alternator harness ?
Offline Eddie
Re: Anybody know which connector should be used ? w/ photo
« Reply #1 on: December 29, 2011, 09:17:14 AM »
not sure about the connector but you can get all kinds of braided sleeving fro Wirecare.com. they have Techflex..
Offline Johnie
« Reply #2 on: December 29, 2011, 10:01:07 AM »
Or give Hondaman a shout. He includes those connectors with his fuse kit. He can let you know where to find them.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Rookster
« Reply #3 on: December 30, 2011, 11:21:59 AM »
The early bikes did not have the locking connector.  I used a zip tie to insure that it wouldn't come apart on mine.
Scott
Offline Killer Canary
  • Typical Bran Muffin
« Reply #4 on: December 30, 2011, 11:37:31 AM »
Don't know if you're aware, but if you can find the proper connector somewhere you can pull the leads out of the disintegrated one and sub the good one. The leads pull out of the back. Maybe other models use the block you're looking for.
Just a thought.
Kawi GPz900, H1
« Reply #5 on: December 30, 2011, 12:20:50 PM »
See:
Vintageconnection.com
But, for the OP's question;  In a world where replacement was not and option, I would use the one that isn't turning to powder.
Markcb750
« Reply #6 on: December 30, 2011, 12:46:27 PM »
+1 on the Vintage connectors stuff.  Nice kits for trying to be period correct, and for custom work with a nice OEM look.
Offline lucky
« Reply #7 on: December 31, 2011, 09:48:18 AM »
You can get a complete new 1975 wiring harness for about $75.00 from Parts-N-More.
That solves lots of problems.
I am using one on my 1978 CB750 K.
« Reply #8 on: December 31, 2011, 09:56:30 AM »
Being a 69 and I think a Sandcast it would be best to try and keep everthing as original as possible and repair what little things that needed fixing if it were mine.
Offline 1080
« Reply #9 on: January 02, 2012, 07:54:29 PM »
Hi greenjeans. In the honda manual page 207 under Supplement to CB750K1 -K4,
Fig20-54 shows a non- locking connector up to the K1's & the change to locking starts for the K2's Fig 20-55.
Keep it original.
Offline greenjeans
  • 1972 CB750K2
« Reply #10 on: January 03, 2012, 05:07:34 AM »
Thanks fellas -
I ordered some stuff from vintage connections.  They look to be identical to the original (non-locking) and should be an easy fix.
I forgot all about those guys.  I ordered some new sleeving for the handlebar controls and the main section of the harness that leads into the bucket.
On a good note - When I removed the headlight bucket the wires had not been touched.  Believe it or not, this is the first motorcycle that I have ever
owned that didn't have some sort of confusion going on in there.
Offline lucky
« Reply #11 on: January 03, 2012, 12:23:10 PM »
You can get a brand new OEM style alternator harness form YAMIYA.
$47.52 USD (3,675 YEN)
Then you can get a complete new wiring harness from Parts-N-More.
It is a 1975.
Just wire it all as a 1975.
« Last Edit: January 03, 2012, 12:28:12 PM by lucky »
