Author Topic: Light panel question  (Read 1111 times)
Offline persson-johan@hotmail.com
« on: December 29, 2011, 08:17:53 am »
Ive just finished my turning signal system. Ive used led blinkers and a new relay.
The thing i cant figure out is how to get the turning signal "sign" lamp in the instrument to flash at the same time.
If i connect it to the original connectors from the handle all four signals flash at the same time because the lamp acts as a cable to connect them all.. If i take one cable from the instrument lamp to the switch from the handle and then to ground it starts flashing but ofcourse only in one of the directions.
Cant really figure this out.
My system is like this except the indicator lights: http://constructionmanuals.tpub.com/14273/img/14273_79_2.jpg
And if i connect it like this it doesnt work: http://data.sohc4.net/WD750/CB750_K3-K7_WD.jpg
/Johan
Offline vames
Re: Light panel question
« Reply #1 on: December 29, 2011, 09:37:01 am »
Diodes. They act like check valves -- electricity can flow in one direction but not the other.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=48nfn7c16k26ii5gj12ocksmu7&/topic,60973.0.html
« Reply #2 on: December 29, 2011, 10:53:05 am »
yes byild a diode on/in the vire to kontrol lamp..then it seperate..think any diode can do it...or bay somelike the start safty diode
its the led blinkers make trobbels..they dont like old type mixing up
« Last Edit: December 29, 2011, 10:57:29 am by strynboen »
i hate all this v-w.... vords
Offline jessezm
  • '77 cb400f cafe build
  • Always wrenching...
« Reply #3 on: December 29, 2011, 10:58:41 am »
Yep, diodes.  Check out post number #39 in my build thread: http://forums.sohc4.net/index.php?topic=70938.25
Just plugged them inline inside the headlight bucket, no problems.  $2 at radio shack for a pack of rectifier type, 3 amp, 50 PIV diodes.
Offline strynboen
« Reply #4 on: December 29, 2011, 11:02:48 am »
or thange the lamp to led in indikator...work same vay
« Reply #5 on: December 29, 2011, 01:17:42 pm »
So on wich cables should the diods be on?
Offline strynboen
« Reply #6 on: December 29, 2011, 01:47:11 pm »
on the kabels to kontrol light
or breake the old lights and use the bottom and veld" led" to the bottom
på dansk..du kan knuse dine pære..bruge soklen..og lodde lys dioden på..lige lime det med araldit så lysdioden sidder fast på bund soklen..så kan du bruge din fatning og montere det i lys konsollen som en andemendelig pære...så vil det hele fungere uden ekstra dioder..og uden nogle ændringer
hilsen lars larsen danmark
du kan også bare montere dioden på ledningen i lygten,,som går op til pæren i panelet...hvad vej dioden skal venne kan du prøve dig frem
« Last Edit: December 29, 2011, 01:49:49 pm by strynboen »
« Reply #7 on: December 30, 2011, 12:03:16 am »
Tack Lars!
Alright, im gonna go and buy some diods and such and figure this out. Thanks for the help!
« Reply #8 on: December 30, 2011, 02:14:03 pm »
Got it sorted out! Led lamp did not work. In only flashed in one direction then! But i connected the two cables from the signals, put some diods on there so all the signals wouldnt flash at once. Then i plugged that wire to the instrument light and grounded the other! Fixed! (: thanks for the help!
