Author Topic: How to nicely refinish the male flare on my caliper body ?  (Read 4061 times)
Re: How to nicely refinish the male flare on my caliper body ?
« Reply #25 on: December 31, 2011, 02:42:30 PM »
I was talking about finned 750/5000 caliper, not sure on the smooth ones....if too damaged you can run Banjo or tap to NPT...not for stock line though..
Offline grcamna2
« Reply #26 on: December 31, 2011, 03:26:18 PM »
It has a little damage but fixable I believe.
Offline Rookster
« Reply #27 on: December 31, 2011, 03:53:39 PM »
The flares do come out.  Some easier than others.  Here's a pic of one sitting on my bench.
Scott
Offline grcamna2
« Reply #28 on: December 31, 2011, 04:02:04 PM »
Rookster,
       I have the smaller caliper,not the CB750...does it still remove ?
« Reply #29 on: December 31, 2011, 04:59:16 PM »
Use a magnet to see if the seat is steel; if it's steel, it can come out. Why do you think it needs repair or replacement? Does it leak?
Offline grcamna2
« Reply #30 on: December 31, 2011, 05:36:24 PM »
Happy New Year Scottly,
      I just checked it w/ a magnet & yes it is steel;I want to repair it or replace it and make it cone shaped again.I bought it from a guy who put the wrong(too small double flare)metal flare pipe end into it & overtightened it a bit & it does leak just a little;is there a replacement part available for my caliper ?
« Reply #31 on: December 31, 2011, 06:08:49 PM »
I have removed the seat by screwing a sheet metal screw into the seat, then carefully prying it straight up out of the caliper.
Offline grcamna2
« Reply #32 on: December 31, 2011, 07:20:18 PM »
Thanks scottly,  before I remove it,does Honda sell a replacement
« Reply #33 on: December 31, 2011, 09:29:20 PM »
Just remachine it on a lathe.. if you cant get it with the nail, tap it instead of using the screw.. then use a nut and washer to draw it out...
Offline grcamna2
« Reply #34 on: December 31, 2011, 09:47:09 PM »
I will first do my best to carefully try to do a bit of lapping it in w/ valve grinding compound as 72500John has first suggested;I want to ask if the correct size metal tubing is commercially available...? can I use automotive brake line? or does it have to be specifically for this from Honda ? It looks to me that a wider flare than what was in there is definitely a good idea.
