Author Topic: Project "Evolution" 78' CB750K... the morphing continues...  (Read 75056 times)
Offline Davidov
  • 1978 CB750 F3
    • My CB750F project log
Re: Project "Evolution" 78' CB750K... more weight savings!
« Reply #25 on: October 17, 2014, 06:09:01 AM »
It's just some old junker foreign bike, why bother with front engine mounts?  :P
I'm interested to see how you revive her, good work so far!
-David
Offline AintNoEasyWay
« Reply #26 on: October 17, 2014, 11:01:25 AM »
Anticipating hearing all about what's left of the pistons & what other surprises lurk down in the engine...
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #27 on: October 19, 2014, 11:52:57 AM »
Amazingly all of the piston pin clips were in place, I was certain at least one would be missing. Anywho, I have bitten the bullet and ordered the 836 kit from cruzinimage on ebay: 65mm pistons, rings, pins, circlips, and head gasket for $120 (+ $25 shipping). Of course, no 836 kit is complete without APE heavy duty studs, so those are on the way as well. The 836 kit will be reserved for my next build (dragbike?). I have decided to use CycleX 1mm over (62mm) pistons for this build to help keep costs in check since I won't be compelled to replace the cylinder studs for such a mild overbore. A cam chain tensioner set from Vintage CB750 will round out the top end refurbishment.
Update: The aftermarket cam chain tensioner was on the verge of self destruction after 1700 miles. I was compelled to tear it down and replace the cam chain tensioner based on this post by member PeWe:
http://forums.sohc4.net/index.php/topic,155043.msg1774841.html#msg1774841
While I'm waiting on those parts I'll go ahead and:
>Replace the alt cover gasket (and extract the damn broken cover bolt while I'm at it) along with new bullet connectors for the stator (these high amp connectors suffer the most). Polish the alt cover while it's off.
>Replace the trans cover gasket, shift seal, as well as the little o-ring behind the countershaft bearing holder. Polish the trans cover.
>Replace the clutch friction plates and drill the clutch hub for better oiling. Replace lifter rod seal and kick shaft seal. Polish the clutch cover.
>Replace the oil pan gasket and repack the oil pump with new o-rings and rubber stopper.
>Replace the output shaft seal.
>Lap the valves, replace valve seals, smooth the head gasket surface.
Picts to follow.
Ought to keep me busy till dinner!
« Last Edit: February 15, 2016, 07:56:11 PM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Davidov
  • 1978 CB750 F3
« Reply #28 on: October 20, 2014, 06:30:47 AM »
I used that one in my 750F, it looks like good quality. The main selling point for me is that it includes so many parts!
-David
« Reply #29 on: October 21, 2014, 06:13:50 PM »
Hey Wilbur.....who will bore?
« Reply #30 on: October 22, 2014, 04:26:53 AM »
who will bore?
I thought I was doing a pretty good job of boring everybody!  ;)
As for the cylinders, member Elan posted a link in the "836 Kits on Ebay" thread to a machine shop that says they can do it for $150 right here in Orlando:
http://www.ebay.com/itm/Kawasaki-Suzuki-Yamaha-Honda-Four-Cylinder-Boring-/250003511909?pt=Motorcycles_Parts_Accessories&hash=item3a355eda65
Which means no shipping costs for me!  8)
Elan gave them a good review so I'm going to give them a shot. My "go to" machinist must be pretty busy (probably because he knows his $hit) since he quoted me $100 per hole ($400 total)!  :o
Hell, I could buy the pistons, pay round-trip shipping to Big Jay (A.P.E.) or Kenny (CycleX) for boring, and still come out ahead for that price...
TAMTF...
Wilbur
Projects:
Offline calj737
  • I refuse...
« Reply #31 on: October 22, 2014, 04:34:16 AM »
Geez! $100/hole!?!? Is the guy a male escort quoting his service prices or a machinist? He must think you're an ungly old fart to charge $100/hole....
My local shop charges $35/hole. And I get great service plus "Please Mr. X and Thank you, Mr X".  They even turn the jobs around within a few days since it's pretty simple...
« Reply #32 on: October 22, 2014, 04:46:55 AM »
Yeah, I about fell out of my chair. Straight-through bore, doesn't get much simpler than that. I was even pricing used machine equipment at that rate, since I've got at least four more motors to do! He did some work for me a few years ago on an outboard motor that was a blind bore (crank main cradle prevented boring clear through) and I don't remember paying anywhere near that price.
TAMTF...
Wilbur
Projects:
Offline mark52
  • 1975 cb750 k5
« Reply #33 on: October 22, 2014, 01:02:02 PM »
Hey Wilbur. I'm glad that Don's prices where more reasonable when he did that work for me. Hope to see you in Valdosta. I think its going to be one crazy weekend.
Mark
Mark
« Reply #34 on: October 22, 2014, 02:24:10 PM »
Mark
It better be, I'm counting on it!  8)
TAMTF...
Wilbur
Projects:
« Reply #35 on: October 23, 2014, 04:23:28 AM »
LOL!
I felt like one of my holes had just been "bored"...
and that was over the phone!  :o
TAMTF...
Wilbur
Projects:
« Reply #36 on: October 25, 2014, 07:25:42 AM »
Made some progress. First of all, I have edited my previous post to indicate that the 836 kit will be reserved for my next build (dragbike?). I have decided to use CycleX 1mm over (62mm) pistons for this build to help keep costs in check since I won't be compelled to replace the cylinder studs for such a mild overbore. Here's a gander at the pistons that were removed (notice two flat tops and two domed):
Cylinders before:
Head before:
More evidence that there wasn't many miles covered in this condition since what remains of the head gasket is easily removed. Too bad that there is still remnants of the previous head gasket still in place.
Prepping the glass (a.k.a. the "elbow mill"). The glas is about 3/8" thick and I use about half a tube of valve lapping compound:
Add spritzes of water until a smooth paste is achieved that can be easily spread:
I work surface of the part from side to side in a circular motion. The compound migrates outward and I have to stop from time to time to scrape the compound back to the center, occasionally adding spritzes of water as necessary. After about an hour on the glass I end up with something like this:
Notice the finish has a glass beaded appearance. This is an accumulation of the lapping compound and needs to be scrubbed off with a scotchbrite or steel wool. I use soapy water and a scotchbrite to reveal actual progress:
And finally after about two hours (each) on the "elbow mill" ("decked" the cylinders too):
The process usually requires replacing the compound once about halfway through so I end up using a full tube to smooth the head. New pistons should be here Tuesday so I can then get the cylinders off to the machinist. Will spend the weekend cleaning, polishing, replacing seals/gaskets, and maybe some painting. When the cylinders get back from the shop I want to be ready to button this up and get it back in the frame!
« Last Edit: May 26, 2015, 04:53:18 AM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Offline Restoration Fan
  • My wife will never call me
« Reply #37 on: October 25, 2014, 02:52:44 PM »
What type of motion do you use?  Circular, back & forth, etc?
« Reply #38 on: October 25, 2014, 03:18:00 PM »
I use small circular motions as I move the part from side to side.
TAMTF...
Wilbur
Projects:
« Reply #39 on: October 25, 2014, 05:34:45 PM »
LOL, thanks.  That's what I get trying to read and comprehend something and watch college football at the same time.
« Reply #40 on: October 25, 2014, 07:27:31 PM »
Got to spend some time sanding and polishing today:
It's not mirror polished, but I like it a lot better than the "patina" (a.k.a. oxidation). Tomorrow I'll test the stator for shorts and replace its connectors. Then I'll install the alternator, shifter cover (with new seal) as well as a new output shaft seal. Once that's done I'll turn my attention to the clutch and oil pump.
TAMTF...
Wilbur
Projects:
« Reply #41 on: October 25, 2014, 07:56:34 PM »
Nice job on the cyl and head, Wilbur.  So, you'll be taking the cyl to the eBay machinist? Curious about him and his shop.
« Reply #42 on: October 25, 2014, 10:54:11 PM »
You are rough on the POST..at 300bux what does it matter? The inside looks like the outside did..
Looks like you need to "mill " more off head at 2 and 3..
 Easy way to do that is use your glass, and sandpaper.. The big stuff can be tough to find.. Then it's an hour job..or less..
« Reply #43 on: October 26, 2014, 07:41:47 AM »
Yeah, the material between two and three is what is imbedded in the ever-so-slight tooling marks from a previous (original?) milling process. I'll lay a straight edge and check for deviations. May go a little further, but my arms are tired! I'll look into the wide paper, thanks for the tip. Cost may be a limiting factor though, since a tube of valve lapping compound is only five bucks (yeah, I'm cheap!).  8)
I haven't talked to the machine shop yet (pistons will be here Tuesday) so I don't know if their base bore job will include decking the cylinders. If so, then I'm done!  ;)
TAMTF...
Wilbur
Projects:
« Reply #44 on: October 26, 2014, 07:43:47 AM »
Yep, he's the cheapest around here. I'll be checking out the facilities and I'll definitely provide a review. Hope he does well, I've got four more to do!
Although, if I had to ship them to get them done I would probably use Pat (A.P.E) or Kenny (CycleX). Pat's a little more expensive, but Kenny can do it for the same price I found locally and Kenny specifies "$150 your pistons or his and includes decking (smoothing pass) the cylinders"
« Last Edit: October 26, 2014, 07:47:24 AM by madmtnmotors »
TAMTF...
Wilbur
Projects:
« Reply #45 on: October 26, 2014, 10:34:35 AM »
Boring usually will not include decking..unless stated as such..
 Usually. Another operation..on another machine.. Some shops charge 50 bux for setup and first cut,but the finish is superb...you may want a bit grippy over dead smooth for gasket to grab...
 If you use have a good straightedge,  and you can get a .0015 feeler under it,get back at it.
Big sandpaper is hard to find, but if you find a wooden door plant or cabinet shop, ask for a broken belt from a stroke sander..sometimes most of the belt is good..and you can do a hundred heads..buy them some beer..
Re: Project "Evolution" 78' CB750K... fer chrisesakes...
« Reply #46 on: October 28, 2014, 02:25:24 PM »
I have decided to have both the head and cylinders machined true. Either my glass is crooked or my technique is flawed, but I'm not satisfied with the results and am going to go ahead and do this right.
Sooooo... found a local guy (Orlando) through the forum here (he's not a member) that has an ad on ebay. Members here had work done there and were all satisfied with the work. Bore and hone to fit new pistons for $150. Turns out he won't/can't hone anything by hand anymore and his machine can't hone anything under 66mm. He can't even do an 836 kit anymore! DAMMIT!
So now I get to take the CycleX pistons, that just arrived TODAY by the way, ship them back to Wisconsin along with the cylinders, just so they can bore/hone/deck the cylinders, and then pay to have the pistons shipped back to me again (along with the cylinders). That's shipping the pistons times three.
I am a patient individual but I'm definitely feeling the pain here...
TAMTF...
Wilbur
Projects:
« Reply #47 on: October 29, 2014, 04:48:23 PM »
Going through the yellow pages, have a couple possibilities:
>There's a guy in Gainesville says he can do it, understands the different clearances for cast vs forged pistons, but that's two hours one way! $160 plus $70 to deck the cylinder. The ebay guy (local) can at least deck the head and cylinder for $30 each.
>Found two shops locally that say they can hone 1mm oversize. One of them wants $300!
>Waiting on a reply from MTC Engineering in Cocoa, about 45 minutes away...
>One local shop says they can do four cylinders for $110. Will have to at least go see them and find out whether they will bore/hone or if they just intend to hone only.
Hopefully I will find a reputable/knowledgeable local shop by the time I'm ready to do the next one. What a PITA!  :o
TAMTF...
Wilbur
Projects:
« Reply #48 on: October 29, 2014, 06:45:37 PM »
Re your last sentence, it may be a pita..but necessary..better to do the legwork now..rather than after they screw you up...
 Re decking.. You got most of it done already.. If you get sandpaper. It will be quick....no need for a lapped surface..
« Reply #49 on: October 30, 2014, 04:06:35 AM »
Yeah, I'm coming to grips with it. I was hoping to be bolting the top end back together this weekend. I've settled into "seek" mode while I try to determine the most cost effective way to get this done right. Patience now should pay off in the long run.
TAMTF...
Wilbur
Projects:
