Author Topic: Crankcase Cradle  (Read 6638 times)
Offline ealanm
Crankcase Cradle
« on: January 02, 2012, 10:00:49 PM »
I made a cradle to hold the crankcase upper half during assembly and dis-assembly.  It seems to work pretty well, so I thought I'd upload a photo and some drawings.
"Speed, it seems to me, provides the one genuinely modern pleasure."
--Aldous Huxley
Offline lucky
Re: Crankcase Cradle
« Reply #1 on: January 04, 2012, 07:20:12 AM »
A very useful tool!  Thanks for the drawing. Why no measurements shown?
« Last Edit: January 04, 2012, 07:22:10 AM by lucky »
Offline ealanm
« Reply #2 on: January 04, 2012, 05:32:50 PM »
They should show, they're on the original PDF -- inches and mm!  Perhaps a problem with your PDF reader?
--Aldous Huxley
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
« Reply #3 on: January 31, 2012, 10:54:51 AM »
The font used doesn't appear to be standard Windows font so no characters are shown.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Offline ealanm
« Reply #4 on: January 31, 2012, 07:14:12 PM »
Possible, I suppose.  But I send PDF drawings created exactly the same way all over the world and I've never run into this before.  I'll try making the PDF on a different machine with a different install of SolidWorks to see if that helps.
--Aldous Huxley
Offline malcolmgb
  • What am I not? an
    • malcnet
« Reply #5 on: February 01, 2012, 08:37:10 AM »
I just downloaded the missing font and it worked ok, I posted the reply to help anyone who is interested. The font is CenturyGothic I got it from http://ufonts.com/fonts/century-gothic.html I assume SolidWorks installs the font and the people you deal with also use it so will have it installed too.
You didn't say which engine it is for but I see from your signature you have a CB750.
« Last Edit: February 01, 2012, 08:51:03 AM by malcolmgb »
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Offline ealanm
« Reply #6 on: February 01, 2012, 07:04:44 PM »
Yes, it's probably the font.  I forgot that I used a different template for that drawing than I usually use.  The normal template has my company name on it, which I wanted to leave off.  So that's probably why the font is different.  I'll change the font and upload a file with a standard font.
And, yes, I built the cradle for a CB750K2, but it'll probably fit any SOHC CB750.
--Aldous Huxley
Offline ealanm
« Reply #7 on: May 29, 2012, 09:49:23 PM »
Okay, I believe I've fixed the font problem.  I've also added an exploded view and some notes, for clarity.
--Aldous Huxley
