Author Topic: Clear coat over polished engine  (Read 1332 times)
Offline stereosilence
  • 1975 CB550K
« on: January 03, 2012, 12:27:26 PM »
Has anyone ever used a heat resistent coat after polishing their engine? I saw a product that you wipe on for a few coats after polishing the engine. It is supposed to withstand the heat and keep everything shiny. Anybody have a word on this?
Here is one I found:
http://classictrimcoat.com/motorcycle-head-engine-refinishing-kit.php
Offline markb
  • When I finish my current project I might be a
Re: Clear coat over polished engine
« Reply #1 on: January 03, 2012, 12:31:25 PM »
I haven't seen that one but I'd be interested in comments.
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline Kong
« Reply #2 on: January 03, 2012, 01:41:09 PM »
Anything that will keep the oxygen off will keep the shine on, but most of the things that are available simply don't work well.  For some parts, like sprocket covers or alternator covers, you can probably have a clear powdercoat put on after you polish them, but like any other coating its going to have problems bonding to a well polished (and cleaned) surface.  Almost no paint will work satisfactorly; there is no opportunity for a chemical bond (how most clear coats work) and because the surface is so highly polished there is also no "tooth", as the painters say, for a mechanical grip.  Think about it this way, when you prep a surface for paint you normally don't sand to any finer than about 400p grit because the paint needs those microscopic scratches to help it adhere.  When you polish an aluminum cover you will be doing something that is roughly akin to sanding with about 8,000~10,000 grit, or so; not much for the clear to adhere to.
As for the wipe-on stuff, the only guess I have about it is that its some sort of wax, which will certainly work for a little while - but only for a little while.  And then of course if you use it and then want to try some other coating you'll have the pleasure of having to completely remove the old wax, usually a task that requires considerable effort.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
Offline grcamna2
« Reply #3 on: January 03, 2012, 02:58:20 PM »
Stereosilence,
        That product has a good write up...if you're in the Atlanta area if would be worth stopping in to one of those places of reference to check out the finished products;I may when I pass through there because I want to know if it adheres well and leaves the original shine.
« Last Edit: January 03, 2012, 03:44:52 PM by grcamna2 »
Offline Ernest T
« Reply #4 on: January 03, 2012, 03:14:36 PM »
I've used duplicolor clear over cases and it's pretty durable, but it eventually turns yellow.  Getting it to stick to polished cases is a trick, spray it with WD40 first otherwise it beads up.
  • 1975 CB550K
« Reply #5 on: January 03, 2012, 03:16:38 PM »
Stereosilence,
        That product has a good write up...if you're in the Atlanta area if would be worth stopping in to one of those places of reference to check out the finished products;I may when I pass through there because I want to know it it adheres well and leaves the original shine.
Good thought. I didn't even look at it that closely. The phone number for the owner is an Atlanta area guy. I may be able to meet him and talk to him about it.
