Author Topic: Oil Sweating  (Read 5150 times)
Offline stereosilence
  • 1975 CB550K
Oil Sweating
« on: January 04, 2012, 07:57:51 PM »
I have oil slowly coming out of the gaskets on the engine. Is there anything I can do from the outside to stop this? I don't want to have to take the engine completely to pieces to change all the gaskets.
Offline rbmgf7
  • 2>4
Re: Oil Sweating
« Reply #1 on: January 04, 2012, 08:41:04 PM »
You can JB Weld all of the seams. That should stop it...
Sorry, that's sarcasm. Hate to tell you but if you want to stop leaks, you need to break the engine apart, condition the surfaces, get a new gasket/seal kit, and retorque everything. Heavy duty studs will help the cylinder-head area.
Re: Oil Sweating
« Reply #2 on: January 04, 2012, 08:56:11 PM »
How bad are the oil leaks? Are they worth pulling the motor? If the leaks are minor, you may want to live with them for the time being, until a rebuild is in order. Of course, I used to have a BSA, so mild oil leaks were not only tolerated, but mandatory to the marque. ;D
Offline crazypj
  • I'm brill, me
Re: Oil Sweating
« Reply #3 on: January 04, 2012, 09:21:59 PM »
CB500/550 always leaks from cylinder/cylinder head gasket.
 I don't bother to fix until it's 4 fins down (then I counter-bore, fit dowel and problem doesn't happen again)
Re: Oil Sweating
« Reply #4 on: January 04, 2012, 10:15:26 PM »
Did I miss where you posted the details of this?
Offline Danno
Re: Oil Sweating
« Reply #5 on: January 05, 2012, 12:27:35 AM »
yeah bud it happens on a lot of them sometimes you can get lucky and spray the gasket groove on the head etc.. with carb clean and they will stop the weeping it makes them swell a tiny bit and that sometimes is enough but if you have a true drip and not a weep it probably will not work
Offline crazypj
  • I'm brill, me
Re: Oil Sweating
« Reply #6 on: January 05, 2012, 07:18:40 AM »
 I don't think I've posted actual details.
 Use a flat bottom counterbore to enlarge 'O' ring recess, counterbore oil hole and fit dowel from 6mm side cover screw. (I think I used alternator cover dowels)
 The only 'hard' bit is making sure the block and head are lined up right.
 I run a 3/16" or 1/4" (forget which, haven't done one for a  long time, been 'playing with XS 650 and CB360's) extra long drill bit from bottom of block  through oil hole with head bolted together (the outer dowels locate head)
 Counter bore head half depth of dowel, oversize 'O' ring, open up hole in head gasket and reassemble.
 I also use copper gasket on 590 motors and don't have any leaks
 It looks like a lot more work when it's written down
Re: Oil Sweating
« Reply #7 on: January 05, 2012, 07:51:03 AM »
a simple re-torque of the head might do the trick.
or stick some tampons between your fins...for those heavy-on-the-throttle days ;D
  • 1975 CB550K
Re: Oil Sweating
« Reply #8 on: January 05, 2012, 09:55:13 AM »
It seems pretty slight. I'll try the carb cleaner thing and probably a retorque. It is not worth pulling the engine (plus I'm worried I wouldn't be able to get it back together properly. I'm about to change the oil. I'm going to put 10W-40 in and probably 20W-50 in the summer. It may be that the oil type effects it.
I have seen liquid gasket stuff before. I was wondering if I could just dab some into the grooves and maybe stop it up some. Does that sound like a bad idea?
Offline bender01
Re: Oil Sweating
« Reply #9 on: January 05, 2012, 10:09:33 AM »
I roll a paper towel tight and push in with a screwdriver. Working for me.
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
Offline Johnie
Re: Oil Sweating
« Reply #10 on: January 05, 2012, 12:28:53 PM »
I have used a small nylon rope pushed between the fins where the leak originates. Works great until I feel like fixing it.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline crazypj
  • I'm brill, me
Re: Oil Sweating
« Reply #11 on: January 05, 2012, 04:55:56 PM »
Bunch of bodgers and shade tree mechanics  ::)
Re-torquing 550 (or 500) head means removing cam cover, if you only do outside nuts you'll probably distort head and have worse problems.
 If you remove cam cover, may as well keep going and do it right
 If it isn't ;wet' leave it until it's 3/4 fins down then do mods described above
  • 1975 CB550K
Re: Oil Sweating
« Reply #12 on: January 05, 2012, 07:51:13 PM »
What do you mean by "3/4 fins down"?
Offline Danno
Re: Oil Sweating
« Reply #13 on: January 05, 2012, 11:23:44 PM »
he means when three to four fin rows down from the leak become visibly wet
Offline crazypj
  • I'm brill, me
Re: Oil Sweating
« Reply #14 on: January 06, 2012, 11:26:12 AM »
Danno has experience of 550's  ;D
Offline dhall57
Re: Oil Sweating
« Reply #15 on: January 06, 2012, 03:19:53 PM »
Oh yeah the old paper towel trick. Works great. I know it only covers up the problem and doesn't fix it, but if the leak is only small IMO it's the way to go until its gets much worse. My 750 K6 has minor seepage and using 4 small neatly rolled up sections of painted silver paper towels keeps the engine nice and clean and its hardly noticeable and just replace them every now and than. It will have to get a whole lot worse before I tackle pulling engine.
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
  • 1975 CB550K
Re: Oil Sweating
« Reply #16 on: January 07, 2012, 07:36:50 PM »
I closely examined the spot around where the oil was and it looks like there is a small section that is missing gasket. I jammed a paper towel up in there. I tihnk I may have some seepage from my oil filter too. Just changed it yesterday though. We'll have to see.
Offline Danno
Re: Oil Sweating
« Reply #17 on: January 08, 2012, 10:45:00 PM »
thanks pj so so you
