Author Topic: Oil lines and fittings for a custom oil tank?  (Read 1484 times)
Offline greddm
    • CB750 Cafe Build
« on: January 10, 2012, 02:31:59 PM »
I'm building a custom oil tank for my CB750 (see pic - and yes I can tape like a pro!) and i'm wondering if anyone knows a good source for fittings and oil lines. I did scavenge the fittings from the old lines and tank, but they look ratty.  I want something that blends in with the engine so as not to draw attention to the lines themselves. I've seen what looks like black braided stainless steel that looked really clean.  I also know that there are several different types of fittings to choose from (AN, JIC, NPT etc.) so if you have opinions on the best, please share.  Also, the tank will be steel not aluminum.
Offline slowjo
Re: Oil lines and fittings for a custom oil tank?
« Reply #1 on: January 10, 2012, 02:49:08 PM »
Check out bung king, and look under oil tanks. This might give you an idea of some common sizes that they use. I have no idea what the stock fitting sizes are but if you are making a custom tank you can make up your own fitting sizes that suites your own needs.
« Reply #2 on: January 10, 2012, 09:53:55 PM »
If yoiu cant find what you need I can make them.. check out the filler tubes I made pic is on ther 750 redux thread in projects.. recent post
Offline greddm
    • CB750 Cafe Build
« Reply #3 on: January 11, 2012, 12:34:39 PM »
I checked the post you mention, and saw pics of the bungs you made (very nice), do you also make the oil lines or were you just talking about the filler?
« Last Edit: January 11, 2012, 01:03:09 PM by greddm »
Offline greddm
    • CB750 Cafe Build
« Reply #4 on: January 11, 2012, 03:02:08 PM »
I found a few items on Cycle Xchange. They have a small selection of NPT fittings and plain black hose, but I would still like to find a source for something with a little more style.
« Reply #5 on: January 11, 2012, 08:44:07 PM »
 I just made those last week, could make one out of steel.. I think the tappet cap is a neat thing to use.
 Most oilines you can put together tourself, with AN stuff... can probably make the fittings if you cant find something you like or want something different.
 If you can lift those pics and move the ( or one of them)m to this thread I would appreciate it, could maybe get some work..
Offline greddm
    • CB750 Cafe Build
« Reply #6 on: January 12, 2012, 12:47:55 PM »
So it looks like you have access to some machining equipment. I dont need a filler bung but i'm sure I'll need some other parts made as the project progresses.  Do you have a mill?  I also posted those pics below for you.
« Last Edit: January 12, 2012, 03:07:59 PM by greddm »
« Reply #7 on: January 12, 2012, 08:31:54 PM »
Thanks for putting up the pics, yes I have a ,milling machine..
Offline Blitzburgh207
« Reply #8 on: February 02, 2012, 10:32:30 AM »
Those are awesome! What a good idea!
1978 CB750 K8
