Author Topic: Metalworking machinery  (Read 4392 times)
« on: January 11, 2012, 09:41:04 AM »
Just being curious, I guess.  What metallworking machinery do you own and use in relation with Honda CB?  Here is my list:
- Lathe Logan 210
- Floor Drill press
- Lincoln MIG
+ angle grinder, dremel, electrical hand drill, sander...
and this is my wish list:
- mill or minimill
- aluminum setup for the welder
- english wheel
- bigger lathe
What do you use/wish for?
Offline kirkn
Re: Metalworking machinery
« Reply #1 on: January 11, 2012, 01:17:18 PM »
A collection of BFH's...  :)
Bench-mounted drill press, vice, bench grinder/wire wheel/buffing wheel, the hand tools you mentioned, air compressor, sandblast cabinet, oxy-acetylene setup, ancient stick welder (not sure of brand).
Wish list:  small welder for misc stuff, more convenient than oxy-acetylene, bigger compressor.
« Reply #2 on: January 11, 2012, 09:06:24 PM »
  9in SouthBend
  16 x 67 lathe
  First mill long table R-8
  Herbert 2D turret lathe
  Drill press used a lot for tapping
 Just got a B&S 618 surface grinder, power feeds.. my new toy..
« Reply #3 on: January 12, 2012, 04:12:22 AM »
754 - WOW!
I am scouting out for a mill nowadays, that's the next step but my ultimate wish is to work again in the tooling factory - http://www.polak.cz/  - you could get anything done there, those guys build replicas of Pedersolli revolvers just for fun.
Offline Danno
« Reply #4 on: January 12, 2012, 12:39:26 PM »
I take my projects to an aircraft factory and use their tools if it is big but most things I do by hand
« Reply #5 on: January 12, 2012, 05:48:51 PM »
Drill press
13x40 Jet lathe
Tool post grinder
Small mill w/r8 spindle
9" rotary table
14" abrasive cut-off saw
Pexto 52" shear
4 1/2" vertical/horizontal band saw
Lincoln mig welder
Bridgeport Series One CNC mill
« Reply #6 on: January 13, 2012, 08:36:37 PM »
 He who dies with the MOST TOOLS wins....
Offline RustyStuff
  • If it aint broke, Fix it till it Is.
« Reply #7 on: January 13, 2012, 08:46:32 PM »
I own-
angle grinder, hand drill, bench grinder and a forney arc welder.
But I have access via family -
a benchtop and floorstanding craftsman drill presses
200amp Miller stick
36x18ish milling machine
12x36 atlas lathe
14x40 chinese lathe
300amp 3 phase mig
Tig
Oxy acetaline
chop saw
Horizontal and vertical bandsaw
bench grinders
plasma cutters
benders
hydro press
etc.
'80 CB650
Offline Gonzowerke
  • I burn asses like a Bhut Jolokia, 'cause I'm a real
  • Member #106, Owner of the ORIGINAL Frankenbike!
« Reply #8 on: January 14, 2012, 01:14:19 AM »
Hand drill, sawzall, angle grinder, spray guns.
A local BMW Motorrad tech is a mill whore and does any work I need on one of his 5 mills or 4 lathes.
Will give my left nut for;
TIG
Lathe
Mill
Spraybooth
1977 F2 "Highway Star"
1977 F2 "Bike-In-A-Box"
1978 K8 "Frankenbike"
1991 CRX Si "Buzz Bomb"
2000 Jeep Wrangler "UBoat"
2011 BMW S1000RR "TIE Fighter"
« Reply #9 on: May 08, 2012, 09:13:09 AM »
 Going to look at a Clarkson Tool & Cutter grinder tommorow, it will be in my shop soon.. and a Victoria Universal mill with Verical head and tooling..for a buddy. Plus I am getting a blacksmiths leg vise and a BIG ARBOR PRESS.. AND MAYBE MORE..
 be swet to finally have a T&C grinder plus the surface grinder I got in December..
Offline mono
  • Definitely no
« Reply #10 on: May 08, 2012, 09:28:31 AM »
leg vises are great!
i don't have much more than a Foredom flex shaft and a polishing motor at home, but i have access to the Toledo Art Museum's metals department where they have a mill and a variety of other amazing metalworking tools - welding, cutting, drilling, a HUGE blasting cabinet, forges, bending jigs, etc.   haven't needed to use much more than the sandblaster for my bike yet, though.
« Reply #11 on: May 08, 2012, 09:35:56 AM »
Good for you, 754  :D
I am jealous actually :)
I got a forge with a blower in February, didnt have time to use it yet and still need to buy better anvil.
« Reply #12 on: May 08, 2012, 09:44:37 AM »
 Got a leg vise here that Dad had, marked St Paul works F&W Can get a big anvil right now (different deal) around 200 lbs, supposed to have lots of tooling.. that is almost always missing...
Offline faux fiddy
  • bike in a box
« Reply #13 on: May 09, 2012, 01:01:43 PM »
I know a shop that got bought out by the christian academy next door. Everything will be auctioned soon.
At least two bridgeports, several lathes, a few cnc machines, water jet cutter, optical comapritor, the list goes on.
Central Oklahoma.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline fastbroshi
  • Puppet
« Reply #14 on: May 09, 2012, 10:05:20 PM »
   If I may go off on a tangent for a sec, I have a quick question I'm sure someone can weigh in on.  Anyone have experience or an opinion about the Atlas 618 metal lathe?  I'm looking at a very early Mk. I model that supposedly works well and comes with extra cutting tools, gears, and the manual.  I'm not impressed with the overall cleanliness of the thing. I'm wondering what would be a fair price range might be.  I appreciate any input.
Just call me Timmaaaaay!!!
« Reply #15 on: May 09, 2012, 10:57:45 PM »
 Do you mean 6 inch swing by 18 inches long.. not sure on them more familiar with the 12inch models.
 We went to have a look at the stuff today, cant move it yet but gathered up bits and searched every nook & cranny.
 My buddy is getting a universal  horizontal mill with Vertical head, a Victoria, I get the Clarkson Tool&cutter grinder.
Then we got 3 Europe made Boring heads, dividing head with nice 8 inch chuck, Shopmade toolpost grinder, set of broaches and bushings, collet set, about 80 horizontal milling cutters, and a few arbors, tapping head,  the blacksmith leg vise, 3 ton arbor press, and a bit of other stuff..
 Best dayout of the shop we had in a very loooonnnngggg time...
Offline fastbroshi
  • Puppet
« Reply #16 on: May 09, 2012, 11:10:51 PM »
yup, 6" swing X 18"
Offline Flying J
« Reply #17 on: May 10, 2012, 12:36:54 AM »
I have a drill press
A basic mill i got from my dad.
Tig welder with liquid cooling
Mig welder
stick welder
Gas welder
Things i want to buy
Tubing Bender
Plasma cutter
Would love a lathe.
Offline faux fiddy
  • bike in a box
« Reply #18 on: May 10, 2012, 01:30:42 AM »
I will keep you all informed about the sale, but there's everything anyone would want as far as that goes; maybe a month until it is auctioned.  Highest bid, including my friend's CNC that was new when he started there in 1979 or so.  It was his machine, period.  30 years since it was new back then.
« Reply #19 on: May 10, 2012, 04:50:06 AM »
You are too far :(
Offline faux fiddy
  • bike in a box
« Reply #20 on: May 13, 2012, 10:33:42 PM »
Good news, the friend loosing his job just hauled home a deckel maho cnc that does four axis maching, set it up at his brother's shop where there is three phase.  WOO HOO...!!
I'll try to find a pic posted and hot link it.
« Reply #21 on: May 13, 2012, 10:45:10 PM »
 How old is the DECKEL ?, that would be a pricey nmachine...
Offline faux fiddy
  • bike in a box
« Reply #22 on: May 14, 2012, 03:33:04 PM »
Found the pic-  Proud new owner.  Only cost what it took to move it out of storage. I guess he will make some parts for someone that had it.
It supposedly had the software upgraded, it's probably 25 years old.
http://www.practicalmachinist.com/vb/dmg-mori-seiki-gildemeister-maho-cnc/i-got-one-mh700c-246446/
« Last Edit: May 14, 2012, 08:27:01 PM by fiddy of industry »
Offline fastbroshi
  • Puppet
« Reply #23 on: May 15, 2012, 12:54:05 AM »
What a complete and utter douche.  Look at that #$%*-eating grin.  Yes, I'm jealous  ;D
« Reply #24 on: May 15, 2012, 04:09:54 AM »
Nice!!
