Author Topic: Wiring Question - the 3 yellow wires between the stator and rec...  (Read 2035 times)
Offline grumpy
  • ..... '73 750K3 .....
I'm rebuilding the connections between the stator and rectifier.
There are 3 yellow wires that go from the stator, thru the generator harness to an 8-pin connector, and to the Rec.
Does the orientation of these 3 wires matter?
That is, does a certain wire in the stator side have to go to a specific wire on the Rec side?
I'm guessing no since that's AC current, right?
Re: Wiring Question - the 3 yellow wires between the stator and rec...
« Reply #1 on: January 11, 2012, 10:00:35 PM »
Doesn't matter.
Offline grumpy
« Reply #2 on: January 11, 2012, 10:09:57 PM »
Thanks TT
I knew you'd know. Ya know?
Offline Danno
« Reply #3 on: January 11, 2012, 11:07:50 PM »
because it is three phase  as long as they go to the leads for the yellow wires they will be fine
Offline Jonesy
  • Shop Rat
« Reply #4 on: January 12, 2012, 04:53:19 AM »
As the others have said, it doesn't matter. The rectifier is smart and can figure it out..  ;)
