The SOHC/4 World Tour is in under way.
Just got my Carb rebuild kits from keyster for my 76 750,
and the float bowl and each one of the jets and on the misture needle etc......
There are also rings on the drain screws on each float bowl .
ive had great success with their rebuild kits on my kawasaki's but then again, its just gaskets and a main jet(stock sized)/one idle screw. so not much to go wrong. might be different on honda kits?
Quote from: wrenchmuch on January 13, 2012, 02:17:47 pm There are also rings on the drain screws on each float bowl .How early is early? On the K0 there are no "O" rings on the bowl drain screws, they are washers.
Ditto on the Keyster needles not having the right shape. I've used the gaskets and o-rings, but I throw the needle away. If the price is the same, buy Honda OEM parts and you'll be happier.
Anyone got a good source for the Honda OEM carb kits? Does each kit come with jets and needles? Are the sold individually or as a set of 4?thanksAndy
Quote from: andy750 on January 15, 2012, 10:34:27 amAnyone got a good source for the Honda OEM carb kits? Does each kit come with jets and needles? Are the sold individually or as a set of 4?thanksAndyI would like to know as well. Especially for the needles and seats.
Sorry to be dense but does that mean needles are sold individually? Looking at Bikebandit.com they list a needle,jet set at $25.71 - is that per needle or for all 4?
