Author Topic: For those who have done Modern Fork Swaps  (Read 935 times)
Offline cwchan
« on: January 14, 2012, 11:06:27 AM »
Were any of you able to keep your mechanical speedometer?  I've read that with the increased axle size you have to could find a speedo drive with a 25mm ID (in my case) but i haven't seen anyone who had one.  Of the swaps i have seen, ppl have either used electronic speedos with magnetic pickups or gone without speedometers.
I'd like to try & keep the mechanical drive but not sure if a 25mm speedo drive would fit within the space between the fork & the brake rotor.
Offline grcamna2
Re: For those who have done Modern Fork Swaps
« Reply #1 on: January 14, 2012, 12:49:59 PM »
Did you swap the entire front end? or just the forks.
Offline cwchan
« Reply #2 on: January 15, 2012, 09:28:20 AM »
Just the forks.  Like FunJimmy, IndustrialCafe, Squirrley, and Staggerlee
Offline grcamna2
« Reply #3 on: January 15, 2012, 12:02:59 PM »
Hi cwchan,
       I think if you gave some pictures(I'm still trying to learn how to upload ???)and then described the ones you have a bit there may be more feedback.
Offline rhinoracer
« Reply #4 on: January 15, 2012, 06:14:03 PM »
The mechanical drive wouldn't fit inside the setup of mine  >:(
Baja native.
