Author Topic: wait to put on muffler before messing w/ carbs?  (Read 1843 times)
Offline 1974blaze
« on: January 14, 2012, 11:45:35 AM »
so i put a 4-1 on (replacing a 4-2) and have not fitted a muffler yet.  possibly unrelated, but it now is hard starting and needs WOT to fire up.  should i wait to put on the muffler (already purchased rev cove shorty) before removing carbs for cleaning?
Offline WarwickE36
Re: wait to put on muffler before messing w/ carbs?
« Reply #1 on: January 14, 2012, 12:13:01 PM »
Hard to tell from your post if the bike was running (or running well) before the exhaust change.  But, I would fit the muffler before tweaking the carbs.  Exhaust will have a big affect on the running of the bike.  Eliminate all the variable I.e. exhaust and intake 3,000 mile tune up etc.. before tuning the carbs.  That being said, if the carbs are dirty/varnished they will certainly need to be freshened up thoroughly before the bike will run properly.
" Why does anyone get offended by what someone does to their own bike? I dont get it. "
You made me think about it after I cheered knowing someone else would like to know what these control freaks are up to.
 Every time any owner strips whatever precious Honda part the horrified purists parts go up in value. That's not the part that bothers them.
 What bothers them is they sat up late at night, their breast full of wonder and estrogen, unable to sleep, dreaming about their lovely darling and all her glory... and next thing you know someone else doesn't share their emotional deluge and their reaction is they must spread their mind museum as far as they possibly can, taking over as much of the real world as possible.
Drink fast, drive slow, but ride it like you stole it
1974 Cb550 with style
2004 SV650s
Offline 1974blaze
« Reply #2 on: January 14, 2012, 12:31:44 PM »
yeah makes sense thanks.  fyi, running perfect before.
Offline Patrick
« Reply #3 on: January 14, 2012, 12:34:50 PM »
If yu think your carbs need cleaning then this is the time to do it. You probably are not planning to ride the bike without a muffler anyway, so you'll have time to mess with them. Have you ever cleaned carbs?
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline grcamna2
« Reply #4 on: January 14, 2012, 12:47:41 PM »
If you have more a more free flowing exhaust you may need to richen up your main jets some.
Offline 1974blaze
« Reply #5 on: January 14, 2012, 12:55:46 PM »
i have cleaned singles a bunch, on my 78 125s.  this is just 4 times as big i assume?  same otherwise? (75 750f)
worth mentioning i'm in CO at 5k ft elevation, so air is thin.
Offline Patrick
« Reply #6 on: January 14, 2012, 02:04:03 PM »
The innards of the carbs will be about the same, but you will need to synchronize them. First a bench synch and then a vacuum synhc on the bike. Unlike a dirt bike, you've got to make all four carbs work together. It's not hard.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline Ernest T
« Reply #7 on: January 14, 2012, 02:09:03 PM »
Doesn't matter if your muffler was free flowing or not, removing it will change the flow of exhaust gas out of the system.  That will change the way the system fills and empties the combustion chamber which naturally will affect the way it runs.  Put the exhaust the way you are going to use it before messing with the carbs.
Offline 1974blaze
« Reply #8 on: January 14, 2012, 03:33:32 PM »
good stuff guys thanks.
Offline Ernest T
« Reply #9 on: January 14, 2012, 06:09:16 PM »
Here's some of the science behind the design of an exhaust.  I don't think English was the author's first language but its a good explanation.
"During each cycle of combustion, gas flow in the exhaust produced a wave of high pressure. It is logical to assume that a wave of high pressure should also produce a wave of low pressure. At some point in the exhaust system, which is determined by the designers, some of the waves collide.  When the high-pressure wave leaves the tube, the wave of low pressure that follows it, is reflected back. A wave of low pressure promotes filling of the combustion chamber with fresh fuel mixture. Then the reflected wave of high pressure prevents leakage of the fresh mixture through the exhaust pipe. Next wave of her low-pressure scavenge the combustion chamber. The process is repeated, the bike is breathing evenly and well.
The length of each pipe exhaust system carefully calculated to pressure pulses were required to point at a given time. Properly executed release plays a crucial role in engine performance."
When you shorten the system, the pressure waves are no longer working to fill the combustion chamber the same way they were before.
Offline Ernest T
« Reply #10 on: January 14, 2012, 06:14:37 PM »
Here's a link with a better explnation.  It won't lt me copy the text.
http://www.motorcycleproject.com/motorcycle/text/exhausts1.html
Read the section on exhaust wave tuning and you'll understqnd why length is probably more important than restriction.
Offline Rgconner
« Reply #11 on: January 14, 2012, 07:06:22 PM »
Here is another reason:
Your neighbors might still talk to you if you have mufflers on the bike when you run it.
1975 CB550K aka "Grease Monkey"
Offline 1974blaze
« Reply #12 on: January 14, 2012, 10:55:30 PM »
hell i don't even like being on it when its this loud.
i will read the article above tomorrow thanks.
