SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
washers under idle fuel mixture screws on 78 pd carbs
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: washers under idle fuel mixture screws on 78 pd carbs (Read 1679 times)
yzracer2
Full Member
on:
January 14, 2012, 07:11:52 PM »
Hi,
Anybody know where I can get replacement washers that go under idle fuel mixture screws and above the o rings on 78 pd carbs. I am missing 1 washer. Are these important? Will the bike run well without them and the orings in there?
Thanks.
Jon
Last Edit: January 14, 2012, 07:13:49 PM by yzracer2
Logged
brandEn
Old Timer
Re: washers under idle fuel mixture screws on 78 pd carbs
Reply #1 on:
January 14, 2012, 07:24:38 PM »
The washers help to keep the mixture screw from turning on the oring which could tear it. ACE has tiny washers as well as Radio Shack. Radio Shack sells them in a pack though.
Logged
La Flama Blanca
http://forums.sohc4.net/index.php?topic=103818.0
T.A.O.
http://forums.sohc4.net/index.php?topic=76757.0
Danno
Hot Shot
74 CB550,75 GL1000,76 KZ400,77 GL1000,73 CB750
Reply #2 on:
January 15, 2012, 04:41:07 AM »
yes you need both the O rings and the washers
Logged
dakota
Enthusiast
Reply #3 on:
January 15, 2012, 04:57:11 AM »
Here you go:
Keyster K-973WA, AIR SCREW WASHERS AND SLIDE NEEDLE WASHERS
diam ex = 5.15mm
diam in = 3.10mm
thick. = 0.55mm
http://www.siriusconinc.com/pro-detail.php?pid=&product_id=2188
Last Edit: January 15, 2012, 05:29:55 AM by dakota
Logged
cookindaddy
I sure love this bike!
Expert
Reply #4 on:
January 15, 2012, 05:03:10 AM »
Thanks! I wish I'd known about those when I needed one that was missing.
They are metric and have a smaller outside diameter than the standard metric washer of that size. I tried to source from an industrial hardware supplier but they were special order and I'd have had to order 1000 pieces. I ended up asking a friend with a model lathe to make one for me.
Logged
George with a black 78 CB750K (in Lion's Head, Ontario, Canada)
Tree
Enthusiast
CB750K5
Reply #5 on:
January 15, 2012, 05:56:45 AM »
I was missing all four washers for a '78 750F Carbs. Found a post where someone used number four lock washers by flattening them. I found some yesterday at an RC airplane hobby shop. They worked except I had to file the inside diameter with a small round file to make it a little bigger. Seems to work fine now.
Logged
yzracer2
Full Member
Reply #6 on:
January 15, 2012, 09:57:39 AM »
Thanks for the info - I have some on order now from Sirrius
Logged
bollingball
Guest
Reply #7 on:
January 15, 2012, 12:45:44 PM »
I got mine from here they also have a 25 pack of the correct o-rings.
Ken
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
