Author Topic: Worlds Toughest Gasket  (Read 2938 times)
Offline Simpson
  • I ain't no
  • Aged to perfection
« on: January 15, 2012, 04:32:00 PM »
I've pulled apart my beloved CB750 KO to refresh the top end.
On doing so, I've uncorked a foe greater than Godzilla and Superman combined.
This thing is super natural...
The cylinder gasket will absolutely not peel off.
Not with razors (not that I like using them), 3m gasket remover pads, scrapers or chemicals.
Next stop C4, napalm and bullets.
Suggestions welcomed
1970 CB750 K0
1975 CL/CB 360 Mix
Offline luap
  • LAWL
Re: Worlds Toughest Gasket
« Reply #1 on: January 15, 2012, 04:47:12 PM »
I would find a chemical stripper in your area an drop t off to them. in az cost would be around 15.00
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
Offline cmonSTART
« Reply #2 on: January 15, 2012, 04:56:18 PM »
For the really tough ones I use 3m scotch-brite roloc pads on my die grinder.  You have to be pretty careful you don't hurt the aluminum, but sometimes it's the only way.
Or, you could get the Japanese army to start shooting kryptonite bullets at it.
1981 GL1100 Interstate
1978 CB750F Project
Offline chewbacca5000
  • I polish covers!
« Reply #3 on: January 15, 2012, 05:10:15 PM »
I ran into a similar gasket last week on my K3 and Permetex foam gasket remover with the brushed helped out quite a bit.  I used a gasket scrapper and razor blades for a few days followed by the Permetex to get ride of the remaining bit.  This was recommended to me by Hondaman and really helped.  I was considering putting a k6 top end beacause the scrapping was so bad.  This really helped.
Offline Simpson
  • I ain't no
« Reply #4 on: January 15, 2012, 05:28:15 PM »
This gasket seems to be impervious to Permetex Remover, JB Blaster, razors, scrappers, heat...
1970 CB750 K0
1975 CL/CB 360 Mix
« Reply #5 on: January 15, 2012, 05:35:13 PM »
Have you tried some heat, it may loosen the bond between the gasket and the case...
Offline Danno
« Reply #6 on: January 16, 2012, 12:15:24 AM »
have you tried denatured alcohol or acetone I know it would probably give up to MEK but that stuff is major bad for you I have run into some of those gaskets that were put on with some sort of shellac gasket sealer and the heat from the engine turns it into some sort of super glue the best advice I can give you is find something that softens it and then soak it in it for as long as you can then scrapers and roloc discs
Offline Simpson
  • I ain't no
« Reply #7 on: January 16, 2012, 04:41:01 AM »
Today I'll look to buy paint stripper or acetone. Its just laughing at the Permetex.
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Doum
« Reply #8 on: January 16, 2012, 04:58:55 AM »
I ever had to remove a gasket like this.The best way I found,maybe will not work for you,Is to preheat the part in a oven....
Or sandcast
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #9 on: January 16, 2012, 06:36:09 AM »
soak it in diesel fuel for about a week.  i have an old 60 quart cooler i soak parts in to help degreasse an prevent rust buiild from sittin on the shelf.  i change the diesel wekly, and run the used thru the tractor after filtering it.  have had several gaskets come free this way.
MATT
Offline Hannibal Smith
  • 3rd Grade Dropout
« Reply #10 on: January 16, 2012, 08:35:09 AM »
Netflix, and "The A Team" (season 1). I had to just sit there and razor mine off, bit by bit while watching the guys save the downtrodden, and being accused of a crime that they didn't commit.............
Aircooled motors are notorious for "combat locking" gaskets.
Follow my build "P38 Racer" in Project section
Offline markb
  • When I finish my current project I might be a
« Reply #11 on: January 16, 2012, 08:45:15 AM »
I just had one of those myself.   ::)  I've talked to a few people since and they swear by paint stripper.  Even with that I don't think it will remove all at once.  Good luck.
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline crazypj
  • I'm brill, me
« Reply #12 on: January 16, 2012, 08:48:44 AM »
You forgot flame throwers  ;D
 The original Honda gaskets were self vulcanising, wood chisel was the only thing I found useful and treat it like hardwood.
Still a PITA
 Soaking in acetone may work, I've never tried that (don't have a sealed steel drum to put it in, most plastic will/should dissolve and just painting it on makes the air smell funny  ;))
« Last Edit: January 16, 2012, 08:52:32 AM by crazypj »
Offline Simpson
  • I ain't no
« Reply #13 on: January 17, 2012, 05:00:32 AM »
Still a PITA
Add pressure washer...
Gonna give that a "shot" today. Maybe 2700 psi will blow it off.
1970 CB750 K0
1975 CL/CB 360 Mix
bollingball
« Reply #14 on: January 17, 2012, 07:12:26 AM »
If you do use the small point nozzle.
Offline Simpson
  • I ain't no
« Reply #15 on: January 17, 2012, 07:33:21 AM »
Pressure washer now has been used in my assault.
Fairly affective, but not the absolute answer.
After about 30 mins of blasting with the 0 degree point, this is what I am left with...
Next stop, I send in more chemical warfare and scrappers...  :P
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Simpson
  • I ain't no
« Reply #16 on: January 18, 2012, 08:26:24 AM »
Winner!
Here's what works best.
1.) spray with paint remover and sit for night
2.) Pressure wash off or scrap if you have no other means.
3.) buff off remaining with 3M gasket remover to shine
Hope this help someone in the future for a gasket removal process.
Thanks all
Next job honing...
1970 CB750 K0
1975 CL/CB 360 Mix
  • I polish covers!
« Reply #17 on: January 18, 2012, 09:24:49 AM »
Hey great job!  Looks like a terrific result.  Maybe you'd want to consider doing something in the tips section to help others in the future.  Wish I had known about the paint remover.  I have used the aluminum aircraft stuff in the past, but don't care for it burining my hands.  I would use this as a last restort though.
Offline crazypj
  • I'm brill, me
« Reply #18 on: January 18, 2012, 12:26:06 PM »
LOL, one thing that works, an 'apprentice'  ;D
couple of days isn't a problem if your not doing it   ;)
