SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Will a CB750 K8 trans fit in an early K motor?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Will a CB750 K8 trans fit in an early K motor? (Read 847 times)
mycb750k6
"res ipsa loquitur"
Expert
Rocketman
on:
January 21, 2012, 08:31:04 AM »
I know some gears (2,4) are different and some have less cogs on the gears in the later models but what if I swapped everything including the shafts, bearings and clutch? Could I swap the entire trans into the early K case?
Logged
1976 CB750 K6 - GONE
1971 CB750 K1(1)
1971 CB750 K1(2)
1971 CB750 K1(3) - GONE
1971 CB750 K1(4) - GONE
1968 CL 175 Scrambler - GONE
Project K1(2) restore
Rocketman
the technological J
Master
deliciouso!
Re: Will a CB750 K8 trans fit in an early K motor?
Reply #1 on:
January 21, 2012, 09:03:58 AM »
why not just switch bottom ends?keep the jugs, pistons and heads from the other bike
Logged
70 KO...sold to fund the ST
http://forums.sohc4.net/index.php?topic=88800.0(Alpha
74 Kaw 250 Enduro
http://forums.sohc4.net/index.php?topic=124278.0
K4 added to collection!
http://forums.sohc4.net/index.php?topic=104784.0
78 750K...
http://forums.sohc4.net/index.php?topic=60257.0
(Omega)sold to fund the K4
94 ST1100..Gone
72 750 K2 Stay tuned!
754
Really Old Timer ...
Reply #2 on:
January 21, 2012, 09:12:14 AM »
What year K case. out put bearing got wider around 73. if you want to use the loder style sprocket carrier, you should change the sprocket shaft to the shorter (early)one..
Logged
Kelowna B.C. Canada
mycb750k6
"res ipsa loquitur"
Expert
Rocketman
Reply #3 on:
January 21, 2012, 10:11:41 AM »
Hmmmm. well the K8 has VIN 3000..... and the K1 1111... And I considered the K8 bottom end but (1) it's black and (2) I don't know that it's any good either till I open it up. This project has gone south in a hurry.
Logged
1971 CB750 K1(1)
1971 CB750 K1(2)
Rocketman
CycleRanger
No comment about being an
Central Texas Shop Manual Advocate
Reply #4 on:
January 21, 2012, 11:02:58 AM »
K8 output shaft is longer.
Logged
CB750K5 '79 XL250s CL350K3
CB750K3 '76 XS650 '76 CJ360T
mycb750k6
"res ipsa loquitur"
Expert
Rocketman
Reply #5 on:
January 21, 2012, 12:13:29 PM »
Well that's it then. Thanks. How about the shift drum and forks. Are they exchangeable?
Logged
1971 CB750 K1(1)
1971 CB750 K1(2)
Rocketman
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
