Author Topic: Dropped my '73 CB500 oil pan and...  (Read 1104 times)
Offline puppytrax
« on: May 25, 2006, 03:42:53 PM »
...didn't see much of concern...no sludge, no chips, no filings...a little bit of leftover gas/oil mixture...not too much of anything...
But the pan did drop down without any prodding...I was expecting to have to whack it with a mallet after 33 years...but when I loosened the last bolt, it fell right off...
...And so did the oil pickup funnel...is that *supposed* to be a 'floating' pickup??? No o-ring to hold it in place, and it has obviousyt been vibrating/rubbing on the pan...I can see the marks...
Other than that, it all looks good...nice smooth gears, Hi-Vo chain looks OK, nice and clean...
New o-ring & filter and back together! This thing may actually run!...by November...
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
Re: Dropped my '73 CB500 oil pan and...
« Reply #1 on: May 25, 2006, 05:33:27 PM »
Do you have your manuals?
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
Offline puppytrax
« Reply #2 on: May 25, 2006, 05:37:52 PM »
Why, yes, of course...Oh, do you mean did I *read* them???...no...   ::)
Offline puppytrax
« Reply #3 on: May 25, 2006, 06:02:41 PM »
Well, the manual doesn't say anything about o-rings, or clips, or whether it's floating or not...just says to "Mount the screen filter on the lower crankcase"...(pg 39)...it keeps falling off, so I guess it's a real loose fit...held up/on by the oil pan...well, that's OK...it lasted for 5731 miles/33 years, I suppose it'll hold on another couple years...   ;D
