Author Topic: Question for the racers  (Read 1168 times)
Offline lucky
« on: January 22, 2012, 08:33:28 am »
I feel like this question qualifies for you expert opinion.
I have a 1978 Honda CB750K.
Engine has mild road race cam. (hold on......
My question is about carb jetting with, (hold on....)
4 into 2 into 1 exhaust and NO air filtration, just four velocity stacks.
PD style carbs.
I really do not think the stock #35 pilot jet will be large enough but
no one on the other forums seems to have tried any other size of pilot jets.
All they do is say pods do not work and always revert back to the stock airbox
instead of really trying to get the jetting right.
They are the push in style jets.
Also I have one .022 thousandth shim under the non adjustable slide needles.
What is the measurement between notches on the adjustable style slide needles?
I am sure some racers must know.
.050?.062??
Offline voxonda
Re: Question for the racers
« Reply #1 on: January 22, 2012, 09:38:10 am »
PD's from '78 F2:
Measurements between notches: 0.035" (with vernier caliper)
Offline lucky
« Reply #2 on: January 22, 2012, 12:09:16 pm »
PD's from '78 F2:
Thank you very much Voxonda.
I thought the gap was larger. Having accurate info really helps.
I have one brass shim(hardware store washer brass) under my needles.
It measures .022 thousandths. I think one more would not hurt.
Plugs still look clean -no soot .
