Thanks for all the great advice guys.
Jesse, saw your reply in
my build thread, thanks for that. I'll respond here too just in case someone reads this later.
I took your advice and cleaned out the thread as best I could (most of the big stuff came out with the bolt as you can see) and tightened it down as much as I dared. It is more than finger tight but has some play with a spanner on it.
As it's quite easy to get to (just take the breather cover off), I think I'll go looking for a slightly longer screw tomorrow. Might stick a long one in, measure how much is sticking out and work out just how deep the thread goes and find a bolt that is as long as possible. I'm a little concerned as those four bolts essentially hold the cam shaft in place and I certainly don't know enough about engines to even want to take a chance with that!
A helicoil is obviously the long term solution, but where it's located (right under the coils/frame) I think it would require taking the head off just to get to it, even if someone could drill a helicoil in straight enough.
Once I got the rocker covers all back together I then moved onto the next step in the manual... Setting the tappets (valve clearances?). That was a time consuming, fidgety, frustrating chore. There has to be a better way of doing that? Two cumbersome spanners and a flimsy feeler gauge is torture! Any advice for me?
Thanks again for the help guys, couldn't do this without you lot.
Rick.
