Author Topic: main crank bearings  (Read 688 times)
Offline neilbobbett
main crank bearings
« on: January 23, 2012, 02:16:14 PM »
HELP !!! If i am unable to colour code the main crankshaft bearings, how do I work out which ones i need ??  Cheers
Re: main crank bearings
« Reply #1 on: January 23, 2012, 02:19:31 PM »
Plastigauge. Very common problem, very common solution.
http://www.plastigaugeusa.com/
Available at auto stores for less than a few dollars.
« Reply #2 on: January 23, 2012, 02:20:58 PM »
Use the code engraved on the crank, and the one that is stamped on the case to select proper bearing if your crank is within limits.
« Reply #3 on: January 23, 2012, 03:31:01 PM »
I think he is missing one of the 2 and can't put together a "color code".
« Reply #4 on: January 23, 2012, 03:31:55 PM »
PS: 9 times out of ten, if there is not much mileage on the parts, you'll end up with all greens.
