Author Topic: Its time to build a 836 Turbo  (Read 106154 times)
  • Moderator
Re: Its time to build a 836 Turbo
« Reply #225 on: May 14, 2012, 06:25:29 AM »
Ya sure can, PM on its way. ;)
Offline Jim F
  • go baby go
« Reply #226 on: May 31, 2012, 06:44:28 PM »
Well its been a while sense the last post but the build has slowed just because there simply
isn't enough time in the day to run a business as well as Brian,s business  which he is doing the bottom end.
but there have been more parts coming in so everything is here to start the build
I have re-built the oil pump with new o rings and a seal and checked clearances. All is good there.
New clutch plates are soaking in oil and ready to go also
Have the ignition box mounted and ready to mount the boost sensor (Somewhere) as soon
as I have the motor back in and the turbo mounted. I can drill into the intake and run a hose back to the sensor
I have all of the main bearings as well as the con rod bearings are in so we can (When we find time) have a base line
to measure and check clearances. The case studs are in and locked in to place as well
I am making a new dash (so to speak) to mount the tack, boost gauge, fuel pressure and a switch to turn on the fuel pump.
need to re-hang my tail light with some new brackets as the ignition box has the old location for the tail light.
Just some little things to do before we get back to building the motor. Like Frank (Drag-racer) says:
you cant over look the littlest thing with this build and if it takes anther 2 or 3 months to built then thats
what its going to take..................BUT it will be right and it will be worth it when its done
I know you guys probably know I don't do shinny fancy paint jobs but I would like some ideas
on what would look good as far as a paint scheme that would make the turbo stand out as well as the
old school racer look that my avatar has..................Bill is going to fall out of his seat when he reads this
as he is the bling specialist and I am the opposite. I like practical first and foremost but I think  I can go over to Bills
side for this build...................but only for this build.........sorry Bill. So..........any ideas guys on a paint theme?
Back to work on the other side of my shop
Jim
« Last Edit: June 01, 2012, 05:42:37 AM by Jim F »
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline Bill/BentON Racing
    • BentON Racing
« Reply #227 on: June 01, 2012, 06:26:34 AM »
 ;D Yes,I didn't hardly believe what I was reading! ;) Jim,I gotta couple ideas! ;D ;D ;D 8) Bill
BentON Racing Website
BentON Racing Facebook
  • Moderator
« Reply #228 on: June 01, 2012, 08:50:19 AM »
BLING BLING.....who's there ?  ;D ;D ;D ;D ;D ;D ;D
Offline Jim F
  • go baby go
« Reply #229 on: June 01, 2012, 10:19:25 AM »
Well Sam I guess its me but only for a moment and then I am gone
just looking for some ideas for paint...........
Offline dragracer
  • CB750F Dragbike
« Reply #230 on: June 02, 2012, 07:47:34 AM »
Jim, can you PM me some details on the boost sensor. Just want to do a bit of research to see how it interacts with the MSD controller. We need a good retard MAP. Also, might want to consider a wheelie control of some sort to connect in with the retard. It will only take a second for that short wheel base bike under boost to be on its lids- ummm, "boot" for Sam. Ask Brian about the factory wheelie controls they used to put on the water cooled GXSR's as a possible source.
My 2 cents!!!! ???
Offline Jim F
  • go baby go
« Reply #231 on: June 02, 2012, 12:59:57 PM »
Frank
I bought the boost sensor from MSD
part number 23121
Boost sensor map
there are three wires to hook into the box
mine where cut so I had to do a little un-cutting
it comes with the male plug also
call me if needed
Jim
770-367-7320
Offline Jim F
  • go baby go
« Reply #232 on: June 13, 2012, 06:44:37 PM »
Well its been a while sense the last post ....................long days in the weld shop
But I did make a so called dash for the gauges
fuel, boost and switch to turn on the fuel pump in the upper right hand corner
got the coils wired and waiting on some connectors from MSD to wire the male side switch the the boost
sensor
I went to Brian,s today to pick up some welding and he has one more motor that he is putting together
then we can start on the bottom end of mine (Bearings and then assemble) so that should be at the end of next week.
more to come
Jim
Offline Old School Honda
« Reply #233 on: June 13, 2012, 07:02:37 PM »
Subscribed...
Offline NewOldSchool
  • Apprentice
« Reply #234 on: June 27, 2012, 01:03:27 PM »
Same here!
Not putting miles on your bike is like not having sex with your Girl Friend so she'll be more desirable to her next Boy Friend.
Offline Jim F
  • go baby go
« Reply #235 on: July 01, 2012, 08:28:03 AM »
Well its finally time to start to assemble everything and its also getting in to some serious
measuring.............
after hard measuring everything with mikes (Bearing mikes) and bore gauges
this is what the clearances are for the con rods to the crank
the crank dia are as follows
#1....1.4172        2.....1.4171           3........1.4171            4.........1.4170
Bearings are as follows and I matched these as close as  I could
.0587              .0587                   .0586                .0588
.0587               .0587                  .0586                .0586
Big ends on the rods are dead on 1.5362 on all 4
after some adding and subtracting the clearances are as follows
#1......... 0.0016                 2.......... 0.0017              3...........0.0019              4...........0.0018
all the numbers before the measurements are for the cylinders 1,2,3,4
I haven't plastic gauged the mains as of yet
and I will plastic-gauge the big ends also but I need to make a fixture to lock the crank to the case so the rods
don't move and check the clearances again and double check everything
Jim
I moved around the bearings and now I have the clearances of 0.0017/0.0018
just need to get the recommended clearances for this type of motor and order the right bearings
« Last Edit: July 02, 2012, 06:14:21 AM by Jim F »
« Reply #236 on: July 01, 2012, 09:59:32 AM »
Jim,
That's some serious looking #$%*! Why not lighten the crank?
Offline Jim F
  • go baby go
« Reply #237 on: July 01, 2012, 01:18:29 PM »
It has been but just-not what everyone is use to seeing
(knife edge) I wanted more mass and strength plus
It's been balanced and nitrided
I sure don't need somthing that spools up
Like a 2 stroke on steriods
Jim
Offline L3niin
  • My First 500
« Reply #238 on: July 02, 2012, 10:01:28 AM »
complete insanity !
I love it !
MyFirst cb500
cb550 77
Offline Leino
  • Not much of an
  • in drag racing since 2005
« Reply #239 on: July 02, 2012, 10:11:34 AM »
Jim is my friend and I resent you calling him insane.  >:( >:( >:( >:( >:( >:( >:( >:( >:(
Sam.  ::)
Offline Jim F
  • go baby go
« Reply #240 on: July 02, 2012, 01:23:16 PM »
INSANE is when I build my second motor that will also be a turbo but in the 1000cc range with a mike Rieck
cylinder and head.............either insane or just stupid but it will sure be fun while it lasts...........
Jim
but I am a little off kilter Sammy but thanks anyway............
your my buddy also...........:)
« Last Edit: July 02, 2012, 01:24:53 PM by Jim F »
Offline Jim F
  • go baby go
« Reply #241 on: July 13, 2012, 09:45:25 AM »
Its finally starting to go back together again
Got all of the bearings measured and where sent out to WPC  (http://www.wpctreatment.com/)  in California on Monday.
got an E-mail from them on Tuesday and they are finished and should be here Monday of next week
Its really going to start to move and I am looking forward to getting this one done and on the dyno
Jim
Offline Trevdawg
« Reply #242 on: July 13, 2012, 10:12:07 AM »
Nice
  • Moderator
« Reply #243 on: July 13, 2012, 01:34:26 PM »
Stop yacking man and get on with it. ;D ;D ;D ;D ;D ;D
Sam. ;)
Offline Jim F
  • go baby go
« Reply #244 on: July 13, 2012, 03:28:39 PM »
Yack yack yack
As soon as the bearings
Are back from
Coatings it will start you ol yacker
  • Moderator
« Reply #245 on: July 15, 2012, 12:36:25 AM »
Offline Jim F
  • go baby go
« Reply #246 on: July 21, 2012, 07:30:52 AM »
Turbos generate a lot of heat so my little JC Whittney oil cooler thats been on the bike
for 20 years has done its job and has been very good at it too
but its time to re-tire the little fella and go with something a little more
shall we say cooler
Here it is from Setrab
I think this should do it don't ya think
and a big thanks to Mike Reick for the out put shaft seal as I didn't know why the seal for
my 75K model would not work. I then realized that this was changed when I built the motor 20 years ago
and I just plain forgot what I did
for those who don't know the 78 750 has a much beefier shaft (69.5mm versus a 65mm) that will work on the early cases
if you noticed there are 2 locator ring grooves and the larger shaft will locate to the outer groove with a wider bearing
but its here and the bottom end is ready to button up
thanks again Mike
    • BentON Racing
« Reply #247 on: July 21, 2012, 08:13:22 AM »
Nice! Some bling in there for sure! ;D 8)
Offline Jim F
  • go baby go
« Reply #248 on: July 21, 2012, 08:21:40 AM »
WHAT WHAT Bling...................where?
I need to get that out of there................
No bling here......................well maybe a little
Offline johno
« Reply #249 on: July 21, 2012, 05:07:54 PM »
 8) 8) 8)  With that oil temp reduction unit  ;)  There is no doubt Jimbo... you will be the coolest dude on the block.
Mate your going well on the build, I'm digging it. When I retire I just want to read threads like this all day until its my turn to go.
Just read LMP Simo's thread and he is having leaks from his main bearing case studs ????
Remember me Jim, one bolt one photo. ;D
Cheers Mate    .....  Johno
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
