Author Topic: Its time to build a 836 Turbo  (Read 114336 times)
Offline BLUE71TURBO
Re: Its time to build a 836 Turbo
« Reply #25 on: January 25, 2012, 10:51:30 PM »
 JIM,  The biggest problem with any carb for a turbo setup is running out of gas when on boost.  The SU carb i run on my A.T.P. setup has a larger emulsion tube, main jet, modified needle and a custom larger fuel bowl to hold more fuel so it won't run out on boost.  MR. TURBO has a custom larger fuel bowl for the HSR carbs. What mods they do to the HSR's i don't know.  I'm going to call them myself to find out. Probably just jet, needle and emulsion tube changes plus the larger bowl.  HSR's can be found used for great prices if you look
on ebay and craigslist.  If your not going to run alot of boost, it won't be to hard to tune.   ;)
Offline Jim F
  • go baby go
« Reply #26 on: January 26, 2012, 06:42:51 AM »
Is there a specific HRS42 or 45 to get?
or are they all the same?
I guess what I am asking is are there any add ones that I need to get
thanks guys and more pictures to follow over the weekend
should have the top end out tomorrow and the rest of the motor over the weekend.
need to start to order parts from Mike soon
I will be going to Livingood Motor-sports to have the Transmission undercut, all bearings will be replaced
Crank will get balanced and cleaned up
more to follow
Jim
give terry a call at mr turbo he has all the parts you will need and he is a hell of a nice guy to talk to
Thanks and I will give him a call this morning
Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline lucky
« Reply #27 on: January 26, 2012, 07:09:34 AM »
Frank, ya need 31s on the 836, believe me.
If Billy chickens out, I'll ride it Jimmy.  ;D ;D ;D ;D ;D ;D ;D ;D
Sam. ;)
Sam excuse my ignorance but what are ("31's").
  • Moderator
« Reply #28 on: January 26, 2012, 07:29:16 AM »
Lucky, 31 is a type of Argon gas that is used when welding Titanium exhaust tubes together. ;D ;D ;D ;D ;D ;D
Just 31mm carburettas. ;)
Sam. ;)
« Reply #29 on: January 26, 2012, 08:09:59 AM »
 Some of us like our Italian 30s and 32s.....lol
  • Moderator
« Reply #30 on: January 26, 2012, 08:20:05 AM »
Don't they do 31s frankie ?
Sam. ;)
« Reply #31 on: January 26, 2012, 08:45:03 AM »
 As far as I know they are in 2mm increments..you could bore a set of 30s to 31mm if desired
« Reply #32 on: January 26, 2012, 07:24:15 PM »
Naw, they come in 1mm increments from 24 to 36. 8)
Offline Jim F
  • go baby go
« Reply #33 on: January 27, 2012, 05:10:38 AM »
quick up date,
I sent my used MTC pistons back to MTC to get checked out
They measured this pistons to be 64.5mm but they said they
can be used. I asked Kim if she might have a set of 836 pistons on the back
shelf somewhere. She called me back and said she has a set that has been
on the self for sometime and would sell these at a reduced cost.
New everything from the crank up but I do have a good set of used turbo pistons that can be used
if needed.
I then called Mr. Turbo and talked to there race tech department and I am having a 42mm flat slide set up for a turbo application.
The original Benex Zenith carb is going to be shelved as parts cant be found and limited tuning capabilities.
Mr. Turbo has all of the gaskets and hoses for the Ray-Jay turbo that is out being rebuilt.
They told me that the old wast gate is still a good one for this application and the only thing to replace is the gate spring
So pistons, rings, wrist pins, cir-clips/Buttons are on order as of yesterday
the carb set up gets ordered today
going to get the motor down and start on the transmission hopefully by Tuesday of next week
Then its Mike R turn (Mike I will call you over the weekend)
Jim
Offline dragracer
  • CB750F Dragbike
« Reply #34 on: January 27, 2012, 09:42:57 AM »
Thanks for the update. You are moving right along on this project. It won't be long before this bike will be on the street/strip. I'm stilling working on the same project from last season and its not finished yet-lol.
Offline Jim F
  • go baby go
« Reply #35 on: January 27, 2012, 11:38:31 AM »
I can send you some of the fire that lit me up for my project
I haven't been this motivated sense working on Sams bike a couple of years ago
You can do it Frank.......................Just call if you need some help...................
I will ride my turbo out to S.C.. Be there in 45mins...:)
Jim
  • Moderator
« Reply #36 on: January 27, 2012, 11:47:40 AM »
Turn the boost up a bit and be there in 30.  ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Offline BLUE71TURBO
« Reply #37 on: January 27, 2012, 04:23:10 PM »
 Hey Jim,  did they go into detail as to what mods they are performing on the HSR 42 ?  Also, why replace the wastegate spring ?   The factory one in mine worked to 22lbs boost pressure.
Offline Jim F
  • go baby go
« Reply #38 on: January 28, 2012, 07:36:17 AM »
I am going to order the kit from Mr. Turbo on Monday and I will find out what they do and will PM you the info.
They are very familiar with the ray-jay turbos and have all the of gaskets for them. They will also get ordered
He said that wast gate was just fine and there was no reason to replace it
Just lube the piston and make sure it moves freely
and the  valve moves freely also
The only thing that he mentioned about replacing the spring was to make sure it was a 0-10 PSI spring
but its also out with the turbo getting checked out. The turbo is being rebuilt.
Jim
Offline Amxsteve
« Reply #39 on: January 28, 2012, 09:49:39 AM »
sounds like you are moving along quite fast,i love turbo bikes and cant wait to see yours done as far as i remember there are no sohc turbo bikes in the Toronto area just a #$%*load of turbo 14s and busas. Not to hijack your build but i have a complete atp 750 setup with mtc slugs i will be posting for sale soon just havent gotten around to taking pics
Offline Jim F
  • go baby go
« Reply #40 on: January 28, 2012, 11:06:30 AM »
Look forward to comparing notes steve
thanks
Jim
Offline Jim F
  • go baby go
« Reply #41 on: January 28, 2012, 11:18:36 AM »
Well the top end is off and looks really good but considering that I only had about 500 miles on the bike
in 20 years it should
I  still had molly lube around the cam towers
This pistons look new
Cyinders still measure 2.5585/2,5582 +or- maybe .0002 on all 4 cylinders
I might be able to use these with just a good hone for the MTC pistons
Offline dragracer
  • CB750F Dragbike
« Reply #42 on: January 28, 2012, 01:31:32 PM »
Jim, you should buy these part for spares. My turbo guru says its getting hard to find housings and turbines for the Ray Jay setups. Garrett knock offs are all about but he doesn't advocate using that junk.
Offline Jim F
  • go baby go
« Reply #43 on: January 28, 2012, 02:40:44 PM »
That's a thought
Offline Bill/BentON Racing
    • BentON Racing
« Reply #44 on: January 28, 2012, 04:11:09 PM »
Jim ,my birthday is 8-7-54! ::) You need some competition!! ;) Bill
BentON Racing Website
BentON Racing Facebook
Offline Jim F
  • go baby go
« Reply #45 on: January 30, 2012, 06:32:27 PM »
Up Date 1/30/12
I will post some pictures tomorrow but I am just to tired
I have the engine out of the frame and apart. Found what I think is a bad 4th gear so it will have to be replaced
all the bearings are in good shape as well as the crank mains, big ends
The Pistons will be here tomorrow (MTC 65mm turbo pistons, rings, tool steel wrist pins, cir-clips/Teflon buttons)
and the used set that came with the kit (There still good also)
I talk to Terry Kizer at Mr. Turbo (Nice guy to talk to and very familiar with the ATP systems) and ordered the HRS 42mm Flat slide with all the hardware to mount to the Ray-jay turbo (They have all the parts to re-build the Ray-Jay Turbos also)
also ordered a 0-10 Lb fuel pump, all of the silicon hoses for the intake tracks and the turbo to the plenum.
all of the gaskets exhaust but will have to make the waist gate gasket. (No problem)
I had a long talk with a Mr. Mike Rieck and talked more about what to do from the crank up
Cycle X super rods
Heavy duty case studs and bolts
Heavy duty cylinder studs and head bolts
Heavy duty primary chain
Heavy duty cam chain
Some port work
oversize intakes and exhausts (If I herd Mike right)
bronze guides
Ti retainers and heavy springs stock keepers
Stainless valves
web turbo cam
cycle x valve cover with the cam tower supports (If Mike didn't buy the last one)
and?????
Its late
see you guys tomorrow
Jim
Offline Jim F
  • go baby go
« Reply #46 on: February 01, 2012, 11:42:36 AM »
The first of many different orders are starting to come in
65mm MTC Turbo pistons are here and will go out for coatings
    • BentON Racing
« Reply #47 on: February 01, 2012, 05:38:29 PM »
Jim,good work,moving right along.64 S90 went away couple hrs. ago.852 kilometers!
More room for 750's!!!!! ;) ;D
Bring all trans,gears and shafts on Sunday.We can match up.Lots BE parts in Z "cave"! ;D I need to get with Mike on CR info.Thanks,Bill
8-10lbs boost made my 75 750 run 8.00 on first 1/8 mile pass.15-20 things get real interesting,I mean broken!That's as quick as Calendar Girl and a litle quicker than Samauto. I'm thinking of that country song,Ain't no swingarm long enough...fo you!
And no wheelie/sissie bars!!! ;D Bill   First Dobie was named Turbo!  ;D
Offline y2kc0wb0y
  • B00msh0cka
  • Shoot the pickle....
« Reply #48 on: February 01, 2012, 06:25:59 PM »
Boost gets you laid :)
CB750K3 890cc| 2004 VFR800A| 76 CB550F| 77 CB750F| 73 CB350G| 79 XLH| 2007 BMW R1200GS| CB750K2
Offline BLUE71TURBO
« Reply #49 on: February 01, 2012, 07:04:44 PM »
    No,  Boost makes yer ball's grow bigger !!     :o   ;)
