Author Topic: Its time to build a 836 Turbo  (Read 106177 times)
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
Re: Its time to build a 836 Turbo
« Reply #250 on: July 21, 2012, 06:20:52 PM »
What size fittings did you use for the cooler?
Offline Jim F
  • go baby go
« Reply #251 on: July 22, 2012, 12:35:57 PM »
got the bottom end buttoned up and everything sure moves nice
especially the shifting mechanism. I had the forks, the shaft and the drum all coated
so it should shift like a knife threw butter
I have new cam chain tensioners (1 stock and one from M3 racing)
I thought that the one from M3 would have the pin and 2 little rubbers to set it into the cases
but NOOOOO. and I cant find the stock rear tensioner so I might need to buy one off of e-bay or make some calls
other things to do before the pistons and top end start to go together
more to follow
The oil line fittings are for a 3/8 ID hose
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline Tintop
« Reply #252 on: July 22, 2012, 01:07:25 PM »
Who did you use to coat the tranny parts?  Sounds like something I should try with my sidecar engine.  It's a pain to shift. :(
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline Jim F
  • go baby go
« Reply #253 on: July 22, 2012, 01:25:13 PM »
The mains and con rods bearings where done from a company in California called WPC
not sure about the company that did this as I had another race shop send all this out but I will
see if Brian will tell me where he did this and I will let you know
Jim
Offline Tintop
« Reply #254 on: July 22, 2012, 02:40:05 PM »
Thanks Jim.
77 CB550 Cafe build
Offline Bill/BentON Racing
    • BentON Racing
« Reply #255 on: July 22, 2012, 03:45:53 PM »
CycleX also does coatings.Nice work Jim!!!! Don't you be buying nuttin off Ebay...Batcave door always open for you! ;) ;D Bill
Just cranked Samauto! 8)
BentON Racing Website
BentON Racing Facebook
Offline Tintop
« Reply #256 on: July 22, 2012, 07:00:31 PM »
Thanks for the reminder Bill.  I knew they did pistons and rockers, I'll ask about tranny parts.
77 CB550 Cafe build
Offline Jim F
  • go baby go
« Reply #257 on: July 26, 2012, 10:18:42 AM »
As my last post stated........I got a little nervous about they way it was shifting and split the cases again
to do a little investigating...........
because the trans was pulled apart for undercutting I checked to see if that was reassembled correctly and of course it was
all of the shifting forks are in the right order.........left, right, and center as marked
shifting drum can only go in one way
everything is good and buttoned up
Got the APE heavy duty cylinder studs in
clutch is reassembled with new OEM fiber plates and Barnett springs
pistons are in as well as the M3 tensioner (Thanks Bill for the lower pivot pins and rubbers) as well as the necessary O rings and stock front tensioner
as well as the base gasket
SO its starting to look like a motor
    • BentON Racing
« Reply #258 on: July 26, 2012, 06:26:14 PM »
Jim,those pistons should be the other way#1 is on dyno side,#4 ignition side! 1-4 left to right. ;) ::),yeh I know had to be me rt! ;D Bill
Offline Jim F
  • go baby go
« Reply #259 on: July 26, 2012, 07:23:06 PM »
but I measured the cylinders the same way from left to right
I like to changes things up
J
    • BentON Racing
« Reply #260 on: July 26, 2012, 07:30:23 PM »
Testing us huh? I'm going to hit you with the bling bat!!! ;D Just wanted to make sure! ;) Bill
Offline ivanhoew
« Reply #261 on: July 27, 2012, 02:17:41 AM »
really nice build jim ,thanks for sharing .
 in case its of any use , i used the stock head gasket on my 400/4 turbo , up to 15 psi and 85 bhp at 8500(when the clutch gave up) it was fine for 10k miles .never a problem .
as someone said earlier , its detonation that i feel blows gaskets ,and with your super stonko msd ignition ,this should be a easy thing to avoid .
heres looking forward to the next installment .
ps i'm guessing 150 bhp ..;-)
just do it .
  • Moderator
« Reply #262 on: July 27, 2012, 03:21:35 AM »
150bhp and a 9 second pass.....
with little Willy on board. ;D ;D ;D ;D ;D
    • BentON Racing
« Reply #263 on: July 27, 2012, 06:11:37 AM »
 ::) Maybe,we'll see,would be nice! ;) ;D ......don't think i'll need to lose any weight for this one!!!!!! ;D Bill
  • Moderator
« Reply #264 on: July 27, 2012, 06:34:10 AM »
 ;D ;D ;D ;D ;D ;D ;D ;D ;D
Offline Jim F
  • go baby go
« Reply #265 on: July 27, 2012, 01:07:35 PM »
moving right along
    • BentON Racing
« Reply #266 on: July 27, 2012, 02:04:53 PM »
Here we go again! You sure about piston direction and fly cuts? ;) ;D Better safe than sorry! Bill
« Reply #267 on: July 27, 2012, 02:05:43 PM »
moving right along
Don't use the oil return sealing rubbers with the MLS gasket Jim. The pistons do not look like the are correct in their respective bores. The larger relief goes on the intake side and are spaced further apart than the exhaust valve reliefs. Dynoman has a good diagram on his website that will show you how it should look.
« Last Edit: July 27, 2012, 02:10:43 PM by MRieck »
« Reply #268 on: July 27, 2012, 05:59:35 PM »
BTW......Where did you get those studs for the 4 center bolt holes??? ;) ;)
    • BentON Racing
« Reply #269 on: July 27, 2012, 06:32:03 PM »
They sure are purty! ;) I need a set or two. ;) ;D Bill
« Reply #270 on: July 27, 2012, 08:00:41 PM »
I got you covered Bill. I will ship this week.
  Mike
    • BentON Racing
« Reply #271 on: July 27, 2012, 10:12:39 PM »
Mike,I appreciate it......Jim...you still at it? I'll stop by tomorrow/today if you home.Bill
« Reply #272 on: July 28, 2012, 01:01:38 AM »
  Mike
Hi Mike, I PM'd you my email addy, are those bolts on the price list, if not include a price for those as well please mate.
Offline mick7504
« Reply #273 on: July 28, 2012, 05:22:19 AM »
moving right along
If I was you
I'd be worried about me.
  • Moderator
« Reply #274 on: July 28, 2012, 08:34:43 AM »
Although It's plain to see that the 1&2 and 3&4 pistons are in the wrong bores, I don't really think that because of the size of the reliefs that Jimmy has them in back to front.
As you look at the pictures, the reliefs on the inlet side are close on central to the center line of the piston where they should be. If they were to be reversed, the large reliefs would be well out of alignment with the inlet valves and the smaller ones would be in the center of the alignment, not where they should be for exhaust reliefs.
Let's remember that these are special pistons made by MTC for a CB750 turbo application and Jimmy did send them back to MTC to have them checked out.
I have seen pistons before that had larger exhaust reliefs and thought WTF.
The best way to check them out if they are not stamped which way is forward is to check the offset of the piston pins.
99% of piston have the pin offset towards the rear by anything from 1 to 3 or 4mm, very few pistons have a central pin.
Sam. ;)
