Author Topic: Its time to build a 836 Turbo  (Read 106188 times)
Offline Jim F
  • go baby go
Re: Its time to build a 836 Turbo
« Reply #325 on: September 06, 2012, 07:41:36 AM »
Hey guys
Are there any good oil temp gauges on the market that I can tie into the oil drain plug?
or where the oil pressure gauge goes
Bill uses a system from Daytona products but I don't like the digital gauge
more of an old school kind of guy
thanks
Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
« Reply #326 on: September 06, 2012, 08:58:20 AM »
Hey guys
thanks
Jim
Hey.....get with it and step into the 90's Jim. ;D
Offline ZanVooden
  • I don't need no stinkin' title
  • This was suppose to be a quick one month job...
« Reply #327 on: September 06, 2012, 09:20:16 AM »
Couple of questions I have for you. Where is the turbo oil supply pulled from? Also the intake manifold has two hoses on it. I assume one is for the boost gauge, what is the other for?
Looks awesome. Cant wait to hear it.
Offline Tintop
« Reply #328 on: September 06, 2012, 10:38:08 AM »
Hey guys
....good oil temp gauges on the market that I can tie into the oil drain plug?
thanks
Jim
A 'Google' for 'oil temperature gauge' will give you lots of choices.  You could also tie it into the fitting for the turbo oil supply.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline Jim F
  • go baby go
« Reply #329 on: September 06, 2012, 12:27:53 PM »
[/quote
One of the hoses goes to the boost gauge and the other goes to the waste gate
The oil pulled in from the main oil galley behind the cylinder where the oil sensor goes
its a special manifold that has 2 openings
goes in to the turbo and then gets dumped into the clutch cover where the other line is
I cant wait to here it also
getting close but the wiring harness needs to be made and then the ignition programed
Jim
« Last Edit: September 06, 2012, 12:31:58 PM by Jim F »
Offline Jim F
  • go baby go
« Reply #330 on: September 06, 2012, 12:28:58 PM »
Hey guys
thanks
Jim
I do that when I get on my RC51 as you well know Mr. Reick
but only then
Offline Jim F
  • go baby go
« Reply #331 on: September 06, 2012, 12:32:42 PM »
Hey guys
thanks
Jim
looking now.........thanks
Jim
Offline Tintop
« Reply #332 on: September 06, 2012, 02:16:33 PM »
Another thought as to where to take oil temp - on the return side from the cooler.  You don't show it any of your pictures, but I assume your using a filter/cooler adapter plate.  A 'T' connector at the adapter would work.  Maybe something like one of these?? - http://aeroquip.cc/aeroquipantopipepressuregaugeadapters.aspx
77 CB550 Cafe build
Offline Jim F
  • go baby go
« Reply #333 on: September 06, 2012, 05:35:20 PM »
Thats a good thought
more later
Jim
« Reply #334 on: September 06, 2012, 05:56:41 PM »
Is this "old school" enough, Jim?
Offline Jim F
  • go baby go
« Reply #335 on: September 06, 2012, 07:47:57 PM »
oh yeah
perfect
Offline Jim F
  • go baby go
« Reply #336 on: September 07, 2012, 11:10:09 AM »
how much Scott?
let me know
Jim
« Reply #337 on: September 08, 2012, 12:45:41 AM »
Are the VDO auto gauges like that weather resistant enough for MC use?  Up under a fairing windshield would give them some protection of course.
Offline Jim F
  • go baby go
« Reply #338 on: September 08, 2012, 06:50:57 AM »
I know no one likes to get into the rain unexpectedly
but I am not sure if the gauges are waterproof or not
need to look in to that.
but if there is the slightest chance of rain then the bike stays
in a clement controlled basement under lock and key.................yeah right
well not under lock an key
I guess I will have to ride the thing and worry about the weather later
damn
Offline Jim F
  • go baby go
« Reply #339 on: September 13, 2012, 06:05:52 AM »
I finally have oil pressure today.................when they say soak the oil pump (And I did)
but what they don't tell you is (And if I built these motors I would have found out)
you have to open the pop off valve (Thats in the pump) that feeds the engine and hold it open until you flood
that side of the oil pump with oil
then release and install the pump, install the oil pan (Don't forget the drain plug)
fill oil tank and turn the engine over for a min or two (Not all at once)
we now have about 30 PSI showing on the oil pressure gauge when I spin the motor over (I am glad I used a good assembly lube)
about time
next step is to get the ignition box hook to 12 volts and check for spark
getting very close to cranking
Jim
(yes it was nerve racking not having oil pressure but we got it figured out)
  • Moderator
« Reply #340 on: September 13, 2012, 06:10:46 AM »
 8) 8) 8) 8) 8) 8) 8)
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #341 on: September 13, 2012, 06:13:37 AM »
Offline Jim F
  • go baby go
« Reply #342 on: September 13, 2012, 07:29:29 AM »
Oh yeah Mike?
that was the reason for the phone calls yesterday
just wanted your opinion about the pump and lack of oil pressure
no need to call unless you just want to shoot the bull (But who has time for that)
thanks
Jim
(Jack says Hi also)
« Last Edit: September 13, 2012, 07:53:20 AM by Jim F »
Offline ivanhoew
« Reply #343 on: September 15, 2012, 12:37:06 AM »
thanks for cracking on with this project so fast jim ,makesa nice build up of anticipation to the first dyno graph  :-)
just do it .
Offline Bill/BentON Racing
    • BentON Racing
« Reply #344 on: September 15, 2012, 04:42:45 AM »
 ;) 8) Great news! ;D...........Jim sounding "desperate" was unusual!  :o I knew it'd be OK. Jimmy,something from MR arrived last night on the doorstep! 8) Can you say 915cc kit and cylinder ready to go!!!!!!!!!!!! Bill
I know,go work on Samauto....OK!  ;D
BentON Racing Website
BentON Racing Facebook
Offline Jim F
  • go baby go
« Reply #345 on: September 15, 2012, 07:24:24 AM »
and the NOPI Nationals are next week too
at atlanta
be there or be square
    • BentON Racing
« Reply #346 on: September 15, 2012, 04:08:39 PM »
I plan on being there and participating!!!!!!!!!!!!!!!!!!!!!! ;D Bill
Offline turboguzzi
« Reply #347 on: September 18, 2012, 06:01:46 AM »
i know its not  a sohc, but if someone is in a real hurry....
http://cgi.ebay.com/ebaymotors/kawasaki-z1r-turbo-z1r-kawasaki-kz-1000-/280966961293?forcev4exp=true#v4-40
sohc or dohc, nice bit o' kit
Offline Jim F
  • go baby go
« Reply #348 on: September 18, 2012, 07:20:14 AM »
Thats a rare bike too
an original ZIR-TC .............nice
Offline dragracer
  • CB750F Dragbike
« Reply #349 on: September 19, 2012, 07:40:18 AM »
Had planned to come but i have a work conference in TN and have to leave early sunday. Dang it!!!!!!
Have fun Bill and be SAFE.
