Author Topic: Its time to build a 836 Turbo  (Read 106216 times)
Offline Jim F
  • go baby go
Re: Its time to build a 836 Turbo
« Reply #350 on: September 20, 2012, 05:40:30 AM »
Judging by what the weather is going to be on Saturday
I think its time to go back to the cool weather jetting
should be a good day
Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline Jim F
  • go baby go
« Reply #351 on: September 30, 2012, 12:07:45 PM »
Today I was able to get caught up on my work and wanted to do a little work in the turbo
Got everything plumed
extra vents from the valve cover
plumbing up the fuel pump and tying in to the fuel gauge (I have about 5 PSI on the gauge)
switched over to a new set of Dyna triggers sense I am using the Dyna pick up (But MSD recommends both)
got the triggers talking to the MSD box and static timed everything. then checked both sets of coils and there both
throwing off a very nice spark. plumed in my oil temp gauge to the feed line going in to the oil cooler
checked oil preasure one more time and its good
No more excuses,................its time to fire this puppy up
and it did after the second or third rotation of the motor..............kinda scard me at how fast it started...........
no leaks and the sound is really something to behold..............
held it at 2000 RPM,s and heat cycled the motor and shut of down al the while checking for leaks...........
all is good
except the over flow hose from the carb is spitting out fuel but I need to check my float hights and adjust
damn this thing sounds good
more to come and a new wiring harness in a couple if weeks when David is done with his season of drag racing..........
  • Moderator
« Reply #352 on: September 30, 2012, 02:07:56 PM »
That all sounded real easy, well done Jimmy boy, I'm proud of ya. ;D ;D ;D ;D ;D ;D ;D ;D ;D
Serious, well done mate. 8) 8) 8) 8) 8) 8) 8) 8) 8)
Sam. ;)
Offline Bill/BentON Racing
    • BentON Racing
« Reply #353 on: September 30, 2012, 04:36:49 PM »
Way Cool! Ride and dyno soon!!! ;) ;D Bling momo if ever! :o Nice work Jimmy!
BentON Racing Website
BentON Racing Facebook
Offline Jim F
  • go baby go
« Reply #354 on: September 30, 2012, 04:45:54 PM »
yep the stator nut was loose
could be worse
thanks Bill
Jim
    • BentON Racing
« Reply #355 on: September 30, 2012, 06:55:01 PM »
You're welcome.Tho,it was the bolt holding on rotor that was loose.Stator is the windings bolted into the dyno cover.Samauto did the same thing last year! ;) ;D Bill
« Reply #356 on: September 30, 2012, 07:08:37 PM »
Great news Jim. I think that seat will come in real handy when the turbo spools up. It should keep you attached to the bike and not sliding off the rear.
Offline Jim F
  • go baby go
« Reply #357 on: October 01, 2012, 05:06:47 AM »
what ever that doohickey is that spins around on the crank that has the bolt that holds it in place
............but thats any way
Offline Syscrush
  • Sold. :(
« Reply #358 on: October 01, 2012, 07:08:56 AM »
The thing that rotates is the rotor.  The thing that stays stationary is the stator.
The thing that kicks azz is this turbo build!  WOW, great work!
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #359 on: October 01, 2012, 07:14:47 AM »
Can't wait to see that pipe on there Jim!
« Reply #360 on: October 01, 2012, 08:10:38 AM »
The rotor bolt on my 1000cc came loose this past Saturday  ......it's an epidemic!  ;D
  • Moderator
« Reply #361 on: October 01, 2012, 08:33:32 AM »
I thought you lot would have known that they need to be more than finger tight. ;D ;D ;D ;D ;D ;D ;D
Sam. ;)
    • BentON Racing
« Reply #362 on: October 01, 2012, 12:20:02 PM »
We probably all used our elbow torque wrenches! ;D Bill
Offline BLUE71TURBO
« Reply #363 on: October 01, 2012, 08:17:45 PM »
 GREAT JOB JIM !!!   ;)     TURBO'S RULE !!!   8) 8) 8) 8)  ;D
« Reply #364 on: October 01, 2012, 08:40:26 PM »
STAYtor Stays..rotor rotates..
Offline Jim F
  • go baby go
« Reply #365 on: October 02, 2012, 05:23:34 AM »
I thought it was the other way around.............
and yes my elbow needed re - calibrating
Mike call me when you get a chance.................weekends are good too
Jim
Offline ivanhoew
« Reply #366 on: October 03, 2012, 12:42:20 AM »
well done jim ,just a thought , is 5 psi ok with that carb ? maybe running it a little lower would stop the overflow . i run my carbs on the turbo 500 at around 3.5 psi .
regards
robert
just do it .
Offline Jim F
  • go baby go
« Reply #367 on: October 03, 2012, 04:19:58 AM »
I am looking in to that Robert
someone else thought that the pressure might be too high
my pressure gauge reads almost 6.5 lbs
I adjusted my floats 1.5mm and will do a test as soon as I can get some
better gas. the gas I was using started to smell a little funny so its getting changed also
will keep you posted
Jim
Offline Jim F
  • go baby go
« Reply #368 on: October 06, 2012, 09:18:22 AM »
Got a fuel regulator and the fuel pressure is 3lbs and the carb does not leak
fired the motor and fuel pressure was stable at 3 to 3.5 Lbs even at 6 to 7k RPMs
one problem solved and many more to go
love the smell of race gas threw a turbo
Jim
Offline 750resurrection
« Reply #369 on: October 06, 2012, 09:55:19 AM »
 So who has a halfway decent guess about how much horsepower that turbo adds ?
 Is it like 57 or 68 stock ?
 I see my 76 motor is 67 stock BHP, well that's an x year 836 so that added a bit and now a turbo too.
 I bet it smokes the tire w/a front brake stand.  ;D
« Last Edit: October 06, 2012, 09:59:38 AM by 750resurrection »
« Reply #370 on: October 06, 2012, 04:47:29 PM »
Depends on the boost. 12lbs will get you, I'd guess 150% to 170% increase. I have to add that you are lucky to 50 to 55HP to the rear wheel with a stock 750
« Last Edit: October 07, 2012, 08:55:28 AM by MRieck »
« Reply #371 on: October 06, 2012, 11:25:14 PM »
A 4 into 1 cammed and ported 75' cb750 Wiseco 836 dyno result on youtube: " it pulled 85rwhp on the dyno ".
No turbo.
'75 Honda CB750 (836cc) Dyno Run
    • BentON Racing
« Reply #372 on: October 07, 2012, 06:19:02 AM »
103-105HP!!! ;) ;D If it it don't....we'll toss the wastegate!!!! ::) ;) Bill
« Reply #373 on: October 07, 2012, 08:57:02 AM »
No turbo.
That is Rick Stetson on the dyno. Had the quickest NA CB in the country at one time.
  • Moderator
« Reply #374 on: October 07, 2012, 09:22:09 AM »
I thought it looked  like Rick, I thought he had put on weight but I guess it was just the fan blowing his clothes out. ;D ;D
A super nice and talented guy. 8) 8) 8)
Sam. ;)
